Running temp.
Old Sep 1, 2024 | 09:48 AM
Bzak1pgh's Avatar
Bzak1pgh
Running temp.
Just wondering if these temps are normal. I drove it about 20 miles then parked, went in store for about 5 min. Smeeled a faint, like rubber, smell...
Inside Temperature, DME Control Unit. 124° F
Air Inake 96.80° F
Engine Temp 230° F
Engine Oil Temp 219° F
Old Sep 1, 2024 | 10:14 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
I recently used my scan tool to monitor engine coolant temp, engine temp, engine oil temp during a 20 min drive. The peak temps were 213F, 210F, and 199F, respectively.
Old Sep 1, 2024 | 03:53 PM
cooper48's Avatar
cooper48
Engine temp is too high. It's possible that your fan is not operating properly. It's also possible, if you have a Gen1, that your crankshaft pulley is separating which would cause the rubber smell. It has a rubber core that over time separates from the pulley. That allows the center to spin but not the actual pulley (at the same RPMs). That would make all your accessories (alternator, water pump, supercharger, etc.) run slower than normal. That's also a good way to ruin your battery and get stuck somewhere with a no-start situation. Check it out.
alconk
Jul 28, 2021 08:58 AM
adolphrettmer
Mar 7, 2016 07:28 PM
LaLa Rocks
May 13, 2010 09:55 AM
shadyyu
R55 :: Clubman Talk (2008+)
17
Apr 4, 2009 06:33 AM
jazztronikk
Mar 13, 2009 10:14 AM
