Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
I am attempting to replace the hatch on my R53. While removing the wire loom I've come across a small module installed on the interior of the hatch door on the driver's side. The module is the antenna disconnecting switch. It has a Roka style plug (part of the wire loom) inserted into the switch. See the attached photo. Problem? There doesn't appear to be a way to disengage the plug from the switch. I've tried everything I can think of (pushing, pulling, turning or a combination of all of these) and have yet to figure out how the Roka plug disengages. The small square openings on the side appear to be a release of some sort but manipulating these has not helped. As a result, I'm unable to remove the wiring loom from the existing hatch door and reinstall it in the replacement hatch door. Also, I cannot figure out why it has a green arrow drawn on it. Aligning this arrow with the green dot below doesn't allow any action. Can anyone tell me how this Roka plug separates from the switch? Thanks.
