Oil Level vs. Negative Rake
Old Sep 10, 2022 | 05:18 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
OIl level is supposed to be checked on level ground but have you ever noticed that our vehicles have a negative rake? This causes the engine to be somehat lower in front than the rear. I'm wondering if the engineers took that in mind when they calibrated the dipstick. Could that be the reason that they specify 4.5 qts trather than 5?
Old Sep 10, 2022 | 05:54 PM
Daftlad's Avatar
Daftlad
For me 5 quarts in puts the level to the top of the dipstick good zone, maybe a smidge higher. I like to check it at known flat ground, usually a big gas station like a truck stop. The 4.5 vs 5 quart thing is both puzzling and somewhat annoying. Most cars seem to take 5 quarts. Willing to bet most of us buy oil in the 5-quart jug. That leaves you half a quart reserve, which you can either leave in the big jug in the garage, throw it into the crank case anyway (not really a good idea), or in my case transfer it into a quart bottle for a roadie top-up. My car doesn't seem to use much oil between changes (3K) maybe a half quart for a lot of city driving, usually nothing for mostly highway miles. So sometimes that bottle goes unused and I end up with a full quart extra after two oil changes.
Old Sep 10, 2022 | 08:55 PM
deepgrey's Avatar
deepgrey
I thought my owner’s manual specified 4.8 quarts for my r50 with a filter change. Isn’t the r53 even more? Or am I misunderstanding?
Old Sep 11, 2022 | 08:16 AM
NC TRACKRAT
Veteran: Navy
All our MINI's have the same block and the same oil change capacity specified ..4.5 qts., although most of us just fill with 5 qts.
Old Sep 11, 2022 | 08:30 AM
deepgrey's Avatar
deepgrey
Then why does the manual have something different?
Oh, and doesn’t the r53 have a tiny oil cooler?
Old Sep 11, 2022 | 10:33 AM
NC TRACKRAT
Veteran: Navy
Obviously, your owner's manual reads differently than mine and the Bentley Service Manual. Not that it's the definitive source, but a GOOGLE search will also show 4.5 qts. The cooler to which you refer is actually a heat exchanger in concert with the oil filter. No additional oil is required.
Old Sep 11, 2022 | 10:57 AM
deepgrey's Avatar
deepgrey
Hmm. Odd. I've always used about 4.8 quarts. It's also what is specified in the factory (or so I thought) docs that I have. I always ignored the 4.5 spec'd in my Bentley because I figured the factory knew what it was doing, and I never showed as overfull.
I'm mostly curious about the discrepancy. I'm unaware of any change during the model run that would alter capacity.
Oil coolers are by definition heat exchangers, aren't they, regardless of what fluid the heat is moved to?
Old Sep 12, 2022 | 05:14 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Interesting.
I do oil/filter changes @ every 3.5k.
I've always filled w/ 4.7 qts. = max level. (R53).
I remember blowing out a rear main (porsche 914) by over filling my crank case by 3/4 qt. R&R those mid engines were a big pita. I'll never forget making that mistake.
Old Sep 13, 2022 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I see 4.8 “LITERS” in those manual quotes…. Except in post #5 where it says 5.1 quarts
4.8 liters = 5 quarts
Old Sep 13, 2022 | 07:04 AM
deepgrey's Avatar
deepgrey
4.8 liters is 5.07 quarts, which rounds to 5.1.
My car takes 4.8 quarts, however. 4.75 quarts if you’re converting from 4.5 liters.
Old Sep 18, 2022 | 09:52 AM
deepgrey's Avatar
deepgrey
I stumbled across the 2003 owners manual a bit ago, and it specs 4.5 liters or 4.7 quarts for both the R50 and R53, like @Here2Go said. Interesting. I wonder what - if anything - changed.
Old Sep 18, 2022 | 10:38 AM
MCS4FUN's Avatar
MCS4FUN
I stumbled on a GP1 press release document dated June 2006 yesterday and saved that for future reference (pdf with related press image moved to new topic here). Very interesting stuff contained within, however this partial specifications page screenshot from that likewise stated 4.8L/5.07qts which seems definitive.
Last edited by MCS4FUN; Sep 18, 2022 at 01:18 PM. Reason: Moved pdf doc & image to new topic in 1st Gen GP subforum
Omar G. Rodriguez
Jun 18, 2019 11:10 AM
davidg5700
Nov 26, 2013 06:46 AM
MiniS2010
Aug 1, 2012 05:06 AM
mimithemini
Dec 30, 2011 06:07 AM
MiniStupidfun
Sep 21, 2007 03:21 PM
