Weird sound coming from passenger side of engine
Old Aug 9, 2022 | 02:26 AM
R52_Alex's Avatar
R52_Alex
Hi, just went on a long trip to brands hatch with no issues then started the car the next day and this noise appeared was wondering what it was and is it good to still drive
https://youtube.com/shorts/SkKxWZawuEc?feature=share
Old Aug 9, 2022 | 07:17 AM
cooper48's Avatar
cooper48
Check the bushings on the hydraulic rod that is part of the belt tensioner. Over time they dry up, then fall out causing the rod to vibrate against the anchor bolts at both (or one) ends. Same thing happened to my 2004 S. You can purchase the hydraulic rod separately from the entire tensioner and it's an inexpensive fix. Access is easy via the right-side wheel well once you remove the fender liner - remove two bolts and replace.
https://www.partsgeek.com/catalog/20...ner_shock.html
Old Aug 9, 2022 | 07:40 AM
R52_Alex's Avatar
R52_Alex
Brilliant cheers, sounds like it's causing an absolute nightmare for the engine, how long do you reckon I'd be able to drive around like that as it's my daily driver and could I do anything to bodge it to keep it going till I can get the part?
Old Aug 9, 2022 | 05:57 PM
cooper48's Avatar
cooper48
Your belt tensioner is somewhat compromised by missing bushings but the noise is more an irritant than a problem (if that is in deed the problem). Pull the fender liner and check it out first.
Old Aug 20, 2022 | 02:45 PM
R52_Alex's Avatar
R52_Alex
turns out the main issue was actually the air filter causing the car to run horribly, but the extra noise sounds like its coming from the supercharger, had a look under the fender liner and the tensioner looked fine, asked the garage and turns out that was replaced too.
BMBULBE
May 4, 2013 12:44 AM
Jolio
Jun 23, 2012 11:05 AM
mike714
Dec 1, 2011 01:43 PM
Morales
Sep 22, 2004 06:05 PM
jh2002
Jun 14, 2004 05:34 AM
