Runs good. Fuel trims seem off. Idles a little rough- not crazy.
Old Jul 8, 2022 | 06:00 AM
madcanvis's Avatar
madcanvis
I’ve had 3 different Indy’s check my compression and all had completely different numbers but each had cylinders within 12%
So I plugged in my handy dandy obd2 scanner and took these screenshots of fuel trims.
1 is at idle ~760rpm and the other ~1060rpm
Also adding a shameless plug for my 2005 R53 (power mods if that matters: all JCW bolt ons except head, JCW 210 dealer map, 17% UP)
Old Jul 8, 2022 | 09:45 AM
mrbean's Avatar
mrbean
Fuel trims seem completely normal.
If you're chasing a rough idle look toward the harmonic balancer or motor mounts.
Old Jul 9, 2022 | 07:31 PM
madcanvis's Avatar
madcanvis
Thanks. Harmonic balancer has about 25k (gel filled) I’ll check the motor mount!
Old Oct 31, 2022 | 06:51 PM
ptkacik's Avatar
ptkacik
Did you find the problem?
eric356
Feb 3, 2016 09:47 PM
mgrant
Jan 17, 2011 09:29 AM
kevinminict
Aug 18, 2007 11:24 PM
HaveBulldogWillTravel
Sep 20, 2006 07:54 AM
SCA
Aug 21, 2003 10:50 AM
