R50 2005 Mini Cooper Base P0455
2005 Mini Cooper Base, 5 speed transmission with P0455 code (Evap system large leak), also the “check gas cap” light.
I’ve replaced my gas cap, and verified that I have the vapor canister/purge valve in the correct orientation and hooked up correctly and still the code comes back after a few miles. Anything else I can check? I’m not sure what to look at now. I’ve read that the vapor canisters can get cracked but I also checked that and mine appears normal on outside inspection. Any ideas would be greatly appreciated, thanks!
