Turning crank without cams installed?
Old Mar 20, 2022 | 05:34 PM
gimmea250swb's Avatar
gimmea250swb
I'm putting my engine back together after a blown piston. With the head mounted and without the cams installed I was able to turn the flywheel by hand to insert the locking pin. After thinking about it, I realized the spark plugs were in and I can hear air flow with the valves closed. Is this normal? It's not easy to turn, but I wonder what I should hear and how difficult it should be to turn by hand since I haven't done this before.
Old Mar 21, 2022 | 11:22 AM
MiniToBe's Avatar
MiniToBe
that is normal. the air will escape through the ring specially on cold spin. also, because you're doing it way slower than a started would, that's also expected to happen.
Brandon Fluharty
Aug 2, 2021 08:40 PM
MiniJonR56
Nov 9, 2020 12:58 AM
Todd Gerken
Jul 18, 2016 06:54 PM
Everyday I'm Motorin
Aug 25, 2013 02:41 PM
Jonauto
Mar 27, 2004 01:28 AM
