R50/53 Crank not turning
Old Jul 23, 2021 | 03:25 AM
Brandon Fluharty's Avatar
Brandon Fluharty
Crank not turning
So I’m doing a rebuild on my engine and just put in stock sized main bearings torqued everything down and tried to turn the crank by hand and it wouldn’t budge but after I loosened the outer crank case bolts and the top inner bolt next to the timing sprocket it spun again(I did put assembly lube on both sides of the bearings but since then have wiped all of it off from both sides) can anyone help me out I’m stumped
Old Jul 23, 2021 | 01:23 PM
mrbean's Avatar
mrbean
Get yourself some plastigauge and use it to check your bearing clearances.
Old Jul 23, 2021 | 03:05 PM
SkiahMutt's Avatar
SkiahMutt
Second this, big time. Advance and some of the other parts houses carry it in stock.
Old Aug 2, 2021 | 08:40 PM
Brandon Fluharty
I got it fixed guys thank you I just cleaned out the bore housings for the bearings and only put lube on the part that comes in contact with the crank and now it turns fine besides being tight from fresh pistons being in it lol
PariDot
Aug 21, 2018 11:22 AM
My.mojo
Sep 29, 2017 12:13 PM
chris50
Jun 29, 2015 11:19 AM
Electrc109
Sep 19, 2003 04:46 PM
