Idle fluctuations (cold and warm)
Old Mar 16, 2022 | 04:09 PM
mike_miniman's Avatar
mike_miniman
Hi - I have a 07 MSC just purchased which needs quite a bit of work. Several issues have been addressed so far (cosmetic / interior related), and now am starting on the engine. It has a lope to it at idle. When I log the timing and mass air flow at idle they both are all over the place. Timing fluctuated from -1 to 18 deg, Mass air flow seems to fluctuate accordingly. It had code p115c, Replaced the mass sir flow sensor and cleared the code, but the behavior remains.
If I unplug the mass air flow sensor while running, the timing settles down and fluctuates from 1-5deg. I know the car needs a timing chain (measured out of spec), and valves are badly carboned (visually checked). Question is: what would cause this behavior? I appreciate all suggestions - thx!!
Old Mar 17, 2022 | 03:55 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Throttle body?
https://www.northamericanmotoring.co...115c-code.html
Old Mar 17, 2022 | 05:07 PM
mike_miniman
Thx Nik!! I'll try that. I also received some good advice to check if I have an internal leak through the valve cover body itself. Which, would not surprise me one bit. I'll report back what I find.
Old Mar 17, 2022 | 10:25 PM
mike_miniman
So I checked for leak through the valve cover, and that didn't change the idle. Then I removed the intake manifold, and searched there for any leaks. Couldn't find any. I removed the throttle body - and it had a lot of carbon on the throttle plate. I cleaned that and operated it several times. Then reinstalled everything, and...it's running MUCH better. Pretty dramatic improvement!
Thx Nik for the tip on the throttle body!
Old Mar 18, 2022 | 03:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Glad you got the issue fixed! These cars are great fun, even with their little personality quirks.
John Puglia
Jun 7, 2019 06:28 AM
Dr. J
Mar 1, 2018 05:37 AM
ChristianCam
Jul 16, 2017 06:43 AM
RedSkunk
Dec 27, 2015 09:16 PM
Marco Guardado
Sep 15, 2015 01:22 AM
