Engine knocking ticking noise R56 N12 1.4
Old Feb 26, 2022 | 04:38 AM
sebastian325's Avatar
sebastian325
Hi folks,
since a few days I have noticed a strange noise, its only when I'm in gear (its an automatic) so under load.
Its not a steady noise and its independent from the RPM.
Timing chain, friction wheel and drive belt had already been changed a few thousand km ago, engine also runs perfectly smooth.
I have read about the water pump drive wheel, but does it sound like this and I wonder why the noise goes away if the car is in neutral.
What I found out, the noise is more or less only when the engine is cold, maybe that helps...
Many thanks in advance for your held and suggestions.
Old Mar 2, 2022 | 04:55 PM
thefarside's Avatar
thefarside
Engine mounts? Sounds like an exhaust pipe knocking on the body.
sebastian325
Feb 21, 2022 02:17 AM
chibullsan
Feb 20, 2022 04:37 AM
omuroff
Oct 3, 2021 11:04 PM
FlyPenFly
Oct 2, 2017 12:48 PM
Ironitri
Aug 4, 2016 10:32 AM
