R56 weird issue - need help diagnosing this problem
Old Nov 9, 2021 | 01:39 PM
  #26
eh-Thomas's Avatar
eh-Thomas
Originally Posted by MiniToBe
The drain plug is the one you see on the pan. There is also a plastic stand pipe that you need to remove. Be gentle with it, it should be hand tight.
Can you please clarify what the “plastic stand pipe” is?
thank you 🙂
Old Nov 10, 2021 | 02:06 AM
  #27
MiniToBe's Avatar
MiniToBe
Sure. When you remove the drain plug, insert the alan key back in the hole and you'll fell the stand pipe. It's purpose to drain excessive atf when you fil it.
The car needs to be running when you add the atf amd once it starts dripping that's when you stop.
Old Nov 10, 2021 | 01:30 PM
  #28
Briscoec's Avatar
Briscoec
It's an over-fill tube
Eh-Thomas, it's like an overfill tube. The tube sticks up inside transmission, when there is too much oil level it spills out, when you pull metal plug. Brilliant design. It's sort of unnerving to remove the drain plug with the engine running. I believe to properly verify level the engine needs to be warmed up. Nevertheless, if oil doesn't come out, with plug pulled it's low. You squirt oil (use a make shift 1/4" tubing stuck on the end of atf container) inside the tube and then remove the inserted plastic tube and the tranny self-levels itself. The level tube is removed by 5mm Allen wrench. The deal is, when you remove it, you have lost exactly how far it sticks up inside tranny. There is no reason to remove it, unless you want to drain the pan of oil. Even draining the pan does not surrender all the fluid. As you know, there is a lot of fluid inside tranny.
Old Dec 13, 2021 | 11:47 AM
  #29
eh-Thomas's Avatar
eh-Thomas
Roll with the punches?
Hey Everybody,
I finally got the courage and time to attempt this operation with my brother in law on this past weekend. Everything was ready except for one thing we didn’t anticipate. The previous guy who worked on my car has STRIPPED the inspection bolt! Now I can’t even remove the plug to do the job 😭😭.
So far, we are all theorizing that I am low on automatic transmission fluid. If this is the case, can I trickle in half a quart of fluid from the top? Are there any consequences to possibly over filling the transmission by half a quart? What are the symptoms of overfilling? [In this scenario, I’m assuming that I can’t remove the inspection plug and at the same time crossing my fingers and hoping for the best😑]
Old Dec 13, 2021 | 12:53 PM
  #30
giorgos's Avatar
giorgos
Which plug do you refer to as "inspection bolt"? Do you mean the drain plug? How is it "stripped"?`And if so: how did the previous shop drain the fluid?
btw: I'd be very careful assuming low fluid level without proof on such a complex hydraulic network as an automatic transmission box.
Mike Miller
Jul 15, 2021 08:49 PM
booyah93
Aug 25, 2019 02:06 PM
Bryan.vfr
Aug 17, 2015 05:33 PM
Boosty
Apr 11, 2013 04:20 PM
GeorgeM3768
R55 :: Clubman Talk (2008+)
Dec 28, 2008 09:34 AM
