Misfire p0300,p0301,p0304
Hey new to the forum having some problems outta my wife's base 2011 mini clubman 1.6 looking for some help.
ISSUES : misfires after warming up I can pull # 4 coil wire and the engine doesn't change but it's fine before warm up and a rough idle on start up.
Things I've Done Compression test ( between 135-129) across cyl. With engine at op temp.Swapped plugs and coil Packs New fuel Filter New intake gasket
checked valves for carbon( look good)
swapped Injectors Checked air Filter Check pcv diagram
Please help anything I'm missing
eliseo1981
Jul 20, 2015 03:56 PM
2003minicooper
May 3, 2012 03:57 PM
