Multiple issues .CEL,AC inop,low voltage,slow cranking . What in common ?
Old Dec 29, 2020 | 11:33 AM
frankiev's Avatar
frankiev
intermittentI've noticed the last week or two a slow cranking issue then yesterday check eng light came on and AC was intermitten . After parking awhile CEL went out and AC was normal
Today CEL came back and AC switch flashing ,intermitten low voltage warning from radar detector ,running rough and slow cranking
I've read about the PS fan and fuses but I'm wondering about the CEL . Anyone know what rhese all may have in common ?
Old Dec 30, 2020 | 11:21 PM
Dan_in_WA's Avatar
Dan_in_WA
Check your battery. How old is it?
Mini’s are notorious for weird electrical problems when the battery gets weak or the charging system isn’t putting out the voltage it should.
Car off and parked, battery voltage should be near 12.6 V and when it’s running should be 14.5 V or very close.
Old Dec 31, 2020 | 04:19 AM
Jason Cornelius's Avatar
Jason Cornelius
Take the battery to an auto parts store and have them check it for you, should be free. When my battery went out it was fine days before, had a weekend on the Dragon. Let her sit for days, then went out boom clicking that was it, tried jumping no luck. Took the battery to oriellys and they were able to get a charge on it but said it was getting ready to go, so I just replaced it. Wife was trying to save the money but in the long run we would have been right back in the same spot so i just bit the bullet. Taking that damn plastic cowl off the swap the battery isn’t bad just something I didn’t want to do twice.
Old Dec 31, 2020 | 05:03 AM
frankiev's Avatar
frankiev
Thanks guys I appreciate the suggestions . It will be a few days before I have time to check things I'll post what I find for others with similar issues
Old Jan 2, 2021 | 08:41 PM
Eric_Rowland's Avatar
Eric_Rowland
Could also be a bad harmonic balancer. Check that it's spinning true, and see if the pulley is loose. The rubber can deteriorate and separate.
Old Jan 5, 2021 | 09:33 AM
nd-photo.nl's Avatar
nd-photo.nl
Good one, how many miles/kms on the clock?
They tend to go out after 100k
Andrew Nedelka
17
Jun 6, 2014 09:35 AM
xcountryfreak
Sep 18, 2013 08:11 AM
MJM472
Jul 29, 2012 09:08 AM
ThomasMini
May 15, 2008 12:36 PM
