Does this engine mount look good to you?
Old Nov 21, 2020 | 06:27 PM
R55Clubman's Avatar
R55Clubman
Link to video
R55 S N18
I just changed the crank seal & gave the engine mount a quick inspection. Didn't see any cracks, leaks (that's water in the vid), or signs of age, but it seemed looser than other mounts I'm used to. I know sometimes mounts sag and wear out before failure. Car seems fine otherwise, I'm just doing routine maintenance.
I have a noise to chase down (minor vibration/buzz at acceleration at lower RPM, like a heatshield), I've found some mentions of a dipstick rattling causing a similar complaint.
I also have a Powerflex lower engine mount insert (the softer/street version) which won't be helping. I didn't check the driver side mount.
Thanks for the guides on the crank seal, it was a lot smoother than expected. I spent more time cleaning grime out of the engine bay and washing my arms than working on the car. For such a small car it sure does find a lot of places to hide
Old Nov 27, 2020 | 09:45 AM
thefarside's Avatar
thefarside
Looks like its sagged big time. The left side is more sensitive to aging than the right - recommend replacing both if older than 5 years.
Old Nov 29, 2020 | 01:22 AM
Lancaster's Avatar
Lancaster
I replaced both on my son's car. They are very accessible, relatively cheap and make a big difference. I have found most to be in poor condition, if the owner recognizes it or not. They are like shocks to me - just replace them. you know they are worn.
Old Nov 29, 2020 | 01:24 AM
Lancaster's Avatar
Lancaster
As far as the noise is concerned, it sounds to me like the friction wheel.
jd_Smith06
Mar 1, 2014 11:31 AM
cargod4490
11
Oct 1, 2012 10:12 AM
Neufusion
Feb 12, 2010 03:24 PM
auscoops
Dec 19, 2008 01:35 PM
