FRM Issue? 2012 S Hardtop 86k
Old Dec 6, 2019 | 03:28 PM
Steve2011S's Avatar
Steve2011S
I assume it's my FRM that went when an alternator was changed. No windows, blinkers, brake light on, red lift, and probably a few more items I don't recall at the moment. I called Century MINI in Greenville, SC and they said it should be covered under warranty. I have driven it a few days and it drives totally fine but I am concerned about driving 60 miles on the highway. Their phones are out at the moment so I can't ask them. I could have AAA tow it and probably will. Should I be concerned?
thanks,
Steve
Old Dec 9, 2019 | 05:31 AM
Lancaster's Avatar
Lancaster
What is an FRM? I’m still learning some of this terminology. If it is an electrical component, can you test functionality with a multimeter?
Old Dec 9, 2019 | 06:20 AM
Lou@Prototype-R's Avatar
Lou@Prototype-R
Vendor
The FRM is the footwell module (ecu) under the drivers door sill that controls lighting among other functions. They have been known to act up after an alternator change or battery reconnect / replacement. Because of placement they are also subject to water damage / corrosion if there is a water leak in the area. Sometimes cleaning the connectors can solve the problems. Occasionally reprogramming can salvage them. It seems a lot of times though the only solution is replacement.
Custom tuning solutions for BMW & Mini.
Old Dec 9, 2019 | 10:43 AM
Lancaster's Avatar
Lancaster
It sounds like it may be the case then. I always test electrical component functionality before replacing as these are usually non returnable items and you can start replacing many items before actually getting the correct one.
kodeyedwardjones
Dec 21, 2025 11:35 PM
Richie the C
Electrical
Oct 8, 2022 05:01 PM
PEneoark
Nov 1, 2019 05:17 PM
MeltingPlastic
Jun 21, 2016 05:15 PM
spyder152
Jun 11, 2015 02:19 PM
