Motive power bleeder
Old Dec 6, 2019 | 09:20 AM
cooper48's Avatar
cooper48
I recently purchased a Motive Power Bleeder. It came with one cap for the fluid reservoir but it's a female thread and my reservoir requires a male thread. Does anyone know if Motive sells different caps that fit a 2004 MINI? I was on the Motive website and it appears all they sell is a complete kit including the tank.
Old Dec 6, 2019 | 09:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Motive sells the adapters separately:
https://www.motiveproducts.com/collections/adapters
Are you sure you need a male adapter? Do you have a picture of your reservoir?
Old Dec 6, 2019 | 09:56 AM
Minibeagle's Avatar
Minibeagle
I agree. I have a Motive power bleeder that I use on my 2006 S and the cap is female...
Old Dec 6, 2019 | 04:03 PM
cooper48's Avatar
cooper48
Reservoir
Here's are a couple pics of my reservoir. You can see that the tank has an internal thread. Are yours different?
Old Dec 6, 2019 | 04:27 PM
Minibeagle's Avatar
Minibeagle
That is the power steering fluid reservoir
Old Dec 6, 2019 | 04:37 PM
cooper48's Avatar
cooper48
Doh! It was the Tequila!
Old Dec 6, 2019 | 07:38 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Old Dec 6, 2019 | 08:34 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
just don't let anyone tell you you need to bleed this one
Old Aug 16, 2020 | 01:44 PM
bump32's Avatar
bump32
This is funny!!!!
But I am trying to figure out which adapter I need for the R53 brake reservoir. For some reason I bought an 1107 and it does not fit... I don't want to buy the wrong one twice.
Can any one confirm the 1100 adapter is the right one???
https://www.motiveproducts.com/colle...ropean-adapter
"45mm threaded adapter for Power Bleeder fits European cars"
UPDATE
I found my answer on the ECS site:
https://www.ecstuning.com/b-motive-p...eder/motivepb/
1100 is the correct adapter for all mini coopers. (for the next guy looking)
Old Aug 31, 2020 | 05:19 PM
AndrewVanis's Avatar
AndrewVanis
FYI, the coolant reservoir cap is the same thread and can be modified for a brake bleeder by installing a nipple.
I built one and used 1/4in irrigation push-in connectors and tubing for most of it. uses the brake fluid container as the supply so there is no pouring out/back.
pfspeeddemon
Nov 14, 2013 02:29 PM
jimaikin
Oct 17, 2011 01:57 PM
Charlie D
Mar 14, 2009 10:10 AM
ahamos
Suspension
Oct 3, 2007 08:31 PM
goaljnky
Dec 25, 2005 10:08 PM
