What is this open temp sensor
Old Nov 25, 2019 | 12:17 PM
torque124's Avatar
torque124
I have a small coolant leak from this sensor as per the picture, is this normal to be disconnected? I have not touched it at all... Just noticed a bit of a leak.
Can I just buy a seal for it?
Old Nov 25, 2019 | 07:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That is the old style sensor from the early N18. Your Thermostat has likely been replaced with the new one that has both sensors in it. So this sensor is no longer used. Normally you replace the hose with the new style that doesn't have that elbow in it.
We have them #1 in this diagram
https://www.waymotorworks.com/oem-co...7-r58-r59.html
Old Nov 26, 2019 | 08:22 AM
torque124's Avatar
torque124
Is that it; "thermostat to upper rad connector" ? Is that common for both manual and auto transmissions? Sometimes they differ... Mine's a manual.
Old Nov 26, 2019 | 11:17 AM
WayMotorWorks
Vendor
yes it is
It was just the sensor and elbow that came from the factory. MINI tried to make the thermostat without the sensor in it so this was how they had to do it, but then it didn't work out so they went back to both sensors being in the thermostat. It's just a production change.
Old Dec 16, 2019 | 05:02 PM
torque124's Avatar
torque124
yes it is
I think you sent me the wrong part, I got this, see attached pic.
This looks exactly like what I have on the car right now, it will not replace that disconnected thermostat housing.. please advise. I was planning to install it today as it is leaking more and more...
NOT happy...
Old Dec 17, 2019 | 09:56 PM
WayMotorWorks
Vendor
I don't know what you ordered. But looking at that pic there that would be the correct hose to replace the one on the thermostat that originally had the temp sensor in it. It does look a lot like the hose under it but they are bent at different angles. So you should be good to go. If you want to send us a pic of your actual hose you can reply to your order invoice email and we'll be happy to look at it.
fixthedoor
Apr 15, 2019 08:00 AM
AZdsrt
Apr 2, 2019 06:54 PM
gglass
Feb 10, 2018 11:44 PM
nimbus9
May 13, 2017 05:18 PM
xmiggzx
Jan 9, 2017 08:04 AM
