Not building boost
Old Sep 5, 2019 | 01:16 PM
Neil Franklin's Avatar
Neil Franklin
Not building boost
So seemingly out of nowhere my car stopped boosting, my gauge reads that vacuum is where it should be and under acceleration I can see it coming out of vacuum but it only gets up to “0” or atmospheric pressure and stops no sound of turbo spool and no sound of diverter valve when gas is released which is normally very audible with my intake. Just pulled the diverter valve and everything looks fine on it. Any advise as to where to look next is appreciated
Old Sep 6, 2019 | 01:13 PM
techman1's Avatar
techman1
Neil,
Have a helper rev the engine while you carefully listen feel for the boost leak under the hood.
No check engine light?
Old Sep 9, 2019 | 05:38 PM
Neil Franklin
Originally Posted by techman1
Neil,
No CEL, charge pipes seemed tight and can’t for sure hear or feel a vacuum leak but with having an aftermarket intercooler and having done the noise maker delete and turbo muffler delete I’m gonna just pull the hot and cold side pipes completely off and re clamp everything
Old Sep 10, 2019 | 11:42 AM
techman1's Avatar
techman1
Noise maker delete, on my list for after cool weather. Hot garage.
How did you do the block-off? Seal still intact?
muquirana
Dec 27, 2017 07:42 PM
Mini for life!
Sep 4, 2011 10:08 AM
70spop
Apr 10, 2008 01:52 AM
not-so-rednwhitecooper
Jul 2, 2006 08:31 PM
LoryIII
Apr 20, 2004 05:32 PM
