High Air Conditioning Discharge Temp (Solved!)
#26
I found this for you
Called my SME again, he suggested removing the compressor and reverse flowing nitrogen through the system at the compressor inlet line to blow oil out of the evap and condenser coils. I would do that, collect the oil and record the amount.
Next, I would pull the compressor and condenser and drain them. Record the amount of oil, and post your amounts for each component. Depending on the amount you collect, I would service the compressor with oil based on what I drained from the system referencing the instructions above.
Thing is my evaporator reads 41F. Which, if the reading is correct, the system is working. Im just not getting the cold air.
#27
Didn't you say earlier that you didn't remove the drain plug as in the video? So you only drained the top end of the compressor. Couple that with your other comment that when you pulled they dryer this time you had oil draining from the condenser, and you stated that didn't happen the first time. Sounds like too much oil to me.
But why is my evaporator temp sensor reading 41F?
#28
I don't know; you said your old evap temp sensor also reported 41 deg F too right? In my case, I have 42 at the evap temp sensor and 43 at the duct (after I fixed my temperature control door). On the other hand, the suction line where I told you to take a temp reading (see previous thermal image), was 114F (41 at evap temp sensor) on your car and 76F (42 at evap temp sensor) on mine. So something is wrong here. Either your evap temp sensor is reporting an incorrect temperature or that Chinese temp gun you have is defective.
The only thing I can think of is there is something wrong inside the plenum, but you have already crimped the heater core inlet and outlet lines and that didn't make any difference. So the temperature rise between the evap coil and the duct discharge is a mystery.
#29
I also suspected its too much oil. BUT why is the evaporator reading 41F?! Can I trust that reading?
#30
Now I'm confused. You didn't know the scanner the evap temperature sensor existed? You've posted a picture of it.
The evap temp sensor reports to the IHKA module (IHKS in my car). You can pull that PID on any good scanner with a live data feature, and you have posted pictures of it. Yes you can trust the reading.
With the car not running, and hot inside, plug in your scanner and pull up the evap temp sensor (if in doubt, check out the video I posted again 3 min 50 sec mark). The evap temp should be very close to the ambient air temp. If it says 41 on a hot car with the engine/AC off, you have a problem!
Next, start the car & turn on the AC to max fan, max cold, and watch that PID. The temperature should drop rapidly. I see a drop of 20 Deg F before I get to the end of the driveway (I have a long driveway).
#31
With the car not running, and hot inside, plug in your scanner and pull up the evap temp sensor (if in doubt, check out the video I posted again). The evap temp should be very close to the ambient air temp. If it says 41 on a hot car with the engine/AC off, you have a problem!
Next, start the car, and watch that PID and the temperature should drop rapidly. I see a drop of 20 Deg F before I get to the end of the driveway (I have a long driveway).
GOOD IDEA! Im gonna do that tonight.
You want me to make things even more confusing? When I blocked/pinched off the hoses to the heater core, I was still getting 60F at the vents. Does this all make any sense? nope.
#32
Check out this email I just received from from Janet T. at SANDEN customer service:
Hello:
I reached out to our overseas office and this was his message.
“please tell the customer the compressor comes with 135cc oil from the factory.
if they try to remove the oil obviously not all 135cc will come out as the inside of the compressor is coated in the oil etc. they should follow best practice for compressor installment and oil calculation “
"Growth is Never by mere chance; it is the result of teams working together."
135cc = 4.56 ouces! No wonder I couldn't get more than 3.5 ounces into the compressor. It kept spilling out because it was already full.
If this thing really came with 135cc ounces in it I have at least 2.5-3 ounces too much in the system.
Hello:
#34
#36
#37
#38
Yes Sir. I have a troubleshooting ticket out with AutoEnginuity. Clearly, something is wrong with the software or the car!
I do not have access to another scanner. I wish.
During the week Im going back to a local shop with a Robinair machine to have them pull 2-3 ounces of PAG oil from the system as they evacuate the system. The Robinair machine has a reservoir on the front that shows how much has been removed when it pulls a a vacuum. Im gonna have them pull 3 oz if possible and see if the AC starts to blow cold.
#40
Lex, check out this post. Scroll down to the end. Very similar to your issue.
https://www.northamericanmotoring.co...ting-help.html
Mark
Mark
BTW we took an additional 1.8-2 ounces out of the system (its still likely has 1 oz too much but Ill never know for sure) and ZERO improvement. Nothing. Same 58-60 F temps.
#41
Mark A
R60 :: Countryman Talk (2010-2015)
02-28-2016 08:45 AM
rodH
31
09-08-2015 06:13 AM
THE ITCH
11-10-2005 11:38 AM
