Stop start neutral position sensor location
Old Mar 20, 2019 | 01:40 PM
snowsports1's Avatar
snowsports1
Hi I have a neutral gear position fault code and it’s not stop starting. I was going to check this sensor but can’t find it and there doesn’t appear to be any information on the web, any help would be much appreciated thanks.
Old Mar 20, 2019 | 01:46 PM
MiniToBe's Avatar
MiniToBe
the sensor is built-in the shifter assembly. also, check the cable if it came loose, this one is near the thermostat.
also, bookmark this newtis.info
Old Mar 20, 2019 | 01:54 PM
snowsports1
Thanks for the quick reply
Old Mar 20, 2019 | 02:48 PM
snowsports1
my car is a manual, do you mean the gear stick end or gearbox end please?
Old Mar 21, 2019 | 04:12 AM
MiniToBe's Avatar
MiniToBe
The manual transmission doesn't have such sensor. Only clutch sensor (on the peddle) and reverse light sensor (a plug goes into the gear selector on top of the transmission)
What is the back story of this error?
Old Mar 21, 2019 | 04:32 AM
snowsports1
I have a fault code saying the neutral position sensor is at fault. There is a sensor required to indicate the car is in neutral for the stop start system (which isn’t working)
Old Mar 21, 2019 | 04:39 AM
MiniToBe's Avatar
MiniToBe
From what i know, the only way for the car to start in manual is if you press the clutch regardless of which gear. I would check the clutch peddle sensor first. If you can run live data, see if the condition changes when you apply pressure to it.
Old Mar 21, 2019 | 05:23 AM
snowsports1
Thanks I have found the sensor on the front of the gearbox, not sure how to test it though.
Old Mar 21, 2019 | 05:35 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...x18823/ZSl42Av
https://www.newtis.info/tisv2/a/en/r...s-hat/H1cGm06b
looking through the links above, i realized my car isnt equipped with this system. the sensor should be actually on the transmission from the front facing the radiator. check for cut or chewed wires..etc
Not sure if the system is in US so, are you in the US?
jimmac
Dec 1, 2014 04:34 PM
'Roy Vernon Zumwalt
Apr 16, 2013 08:01 AM
Motor On
MINI Camera and Video
27
Jan 19, 2007 06:08 AM
Bianca
May 20, 2003 03:39 PM
