Boost Problem! No Codes!
Old Feb 20, 2019 | 06:13 PM
JPark's Avatar
JPark
Can’t for the life of me figure out what the issue is.
09 MCS. Car is extremely slow after 4500rpm. I can only get to about 5-6psi while under 4500rpm and the boost builds slow. The boost drops to next to nothing (0.5-1.5 psi) after 4500ish rpm.
No check engine codes except for my secondary o2
I’ve double checked the vacuum lines. The wastegate has some play but doesn’t seem out of the norm compared to others (based on videos I’ve seen online). DV has no tears. Boost converter has vacuum lines still connected (I don’t get any weird kazoo noises when I turn off the motor). Inspected the turbo, there is no shaft play and it the turbine spins and doesn’t leak oil.
Mods: intake, catless dp, exhaust, intercooler, gfb+ dv
Only thing I can think of is the waste gate (because of the play) but wouldn’t that throw a low boost code?
Old Feb 24, 2019 | 07:40 PM
mkov608's Avatar
mkov608
Have you checked your charge pipe and intercooler for leaks?
Old Feb 25, 2019 | 12:41 PM
MrGrumpy's Avatar
MrGrumpy
It very well may be the wastegate. When mine went out, it still worked, but didn’t seal all the way, so it would build some boost, but not quite as much as expected, especially under a light load.... that’s when I would get a CEL, but it took a very specific set of conditions to get the CEL (light load on an incline at hwy speeds). If it’s not a boost leak, you will probably need to pull the downpipe and check how well it’s actually closing.
Mine was diagnosed with live data logging and a borescope, but without one just pull the DP to check the wastegate.
Also check the wastegate actuator to see if It closes the wastegate at around 15 inHg.
keep us posted on how it goes. Good luck.
kurtsunn
Apr 10, 2018 12:01 PM
ridler
Jun 28, 2011 09:36 AM
atlas3110
Dec 20, 2010 10:17 PM
HighSchoolzMINI
15
Oct 21, 2006 10:47 AM
