CVT Shift cable
Old Jan 28, 2019 | 08:00 PM
Patrick A. Peets's Avatar
Patrick A. Peets
CVT Shift cable
I have a 2002 base w/CVT. Typical issue as it needs a rebuild. So I pulled it out and when through it completely. I have sent it off to the repair shop to have it re-learned. The problem I found when I re-installed the transmission it seemed that the shift cable is too long. Took the car all apart anything that had to do with the shift cable, and couldn't find anything obvious. I ended up cutting the end of the cable off just to get it to shift.
What have I missed or bent or done wrong??
Old Jan 29, 2019 | 02:57 AM
Tgriffithjr's Avatar
Tgriffithjr
I assume it’s the original cable? If it’s mounted on both ends correctly and it shifts properly then leave well enough alone. It would be hard to say from a distance what’s changed. How far off is it? One inche, etc?
Old Jan 29, 2019 | 07:45 AM
Patrick A. Peets
The cable seemed to be about an inch too long. When you put into or try to put into gear the end of the cable would hit the bracket it is mounted to. I cut the end of the cable off just to get it into gear. The shifting feels a bit sticky. I am in search of a replacement cable.
Old Aug 14, 2021 | 07:06 AM
greg.clare's Avatar
greg.clare
Patrick... did you find a solution... I have the exact same problem
trashmanbob
Jun 24, 2017 05:29 PM
Paul!
Electrical
Feb 15, 2015 07:05 PM
texasmontego
Electrical
Jul 11, 2012 09:52 AM
jpatrician
Sep 29, 2011 06:10 AM
