Rattle / Knock from Rear Sunroof
Old Jan 1, 2019 | 09:17 PM
Gubi's Avatar
Gubi
So for the past few years my 2012 MCS has been making this sharp knocking noise when going over bumps. Only happens when it's cold out. I was chasing things on the suspension and exhaust (it's definitely not the sway bar bushings or end links) but after riding around in the back seat for a while I'm 99% sure it's coming from the rear section of the sunroof.
Has anyone seen this before? I checked everything, pulled the glass out, and retightened: I can't see anything that's moving inappropriately, or anywhere the glass might be hitting. It sounds like a hard rap, like you're knocking the window with a knuckle.
Suggestions greatly appreciated.
Old Jan 2, 2019 | 09:13 AM
v10climber's Avatar
v10climber
Have you tried pushing up on the sunroof to see if it goes away when you go over bumps? The front sunroof panel on ours is rattling a little bit and I think it's rattling in the sunroof track. It goes away if you just barely hit the open switch. I haven't had time to really investigate yet.
Old Jan 4, 2019 | 05:14 PM
Gubi's Avatar
Gubi
Yes, that's how I diagnosed the problem. But I can't find where it's hitting: everything looks tight.
Darkness
Dec 9, 2008 11:51 AM
amazonb
May 23, 2008 07:23 PM
Jeffy
Cooper (non S)
14
May 14, 2008 06:46 PM
sprp85
Suspension
May 6, 2008 05:06 AM
bmarvin81
Jan 22, 2003 10:38 AM
