Is this an exhaust leak or something else?
Greetings NAM Folks... Hoping I could pick you guys brains on an issue I'm having..
After doing a head gasket repair + some motor upgrades.. I'm getting a strong oder inside the cab of my 03 R53 JCW when I get on it... Like when I get on the express way. It don't mater whether I have recycle air on the AC ON or off...
It kinda smells like exhaust but not sure. I'm wondering how to diagnose this issue? Is it a simple exhaust leak or possible something else??
When I changed the head gasket I also changed out/upgraded to:
15% pulley
blue fuel injectors
WMW Mild street cam
Exhaust header gasket
Intake manafold gasket
super charger service: the water pump side was completely dry so that O ring is probably leaking
My thoughts is it is one of the following:
- Exhaust leak at the gasket
- Exhaust leak due to cracked flex section of header
- Slipping super charger pulley
- Possible fuel mixture issue due to larger injectors (was hoping my JCW tune would prevent this)
- Super charger oil leaking into the intake
Anyone ever have this issue or know where I can start trouble shooting?
15% pulley
blue fuel injectors
WMW Mild street cam
Too rich mixture is one of my thoughts too.. How much does a tune cost?
He did mine so many years ago that I'd be out of line to say. Give him a call. He requires that you have fresh/recent spark plugs and everything in top shape. Entails dyno pulls and him doing his magic on on your ECU via his computer. Much better than a "canned" tune.
You haven't mentioned these but, IMHO, you're not going to obtain max benefit from your mods unless you have a good tuned exhaust header and a compatible cat back exhaust. I wouldn't do a tune until you install same.
It has the JCW cat back... Was thinking about a header but I want something that won't be too loud and won't cause check engine lights.. I live in Florida so I don't have to pass emissions.. Any recommendations?
skokiedude
Jan 25, 2004 02:51 AM
R50/53 something else just broke
02s79fj40
Nov 26, 2003 07:51 AM
