No spark.
Old Nov 3, 2018 | 10:18 AM
Revevsi's Avatar
Revevsi
No spark.
so it’s been about 4 months since I started dealing with a crank, with no spark. After the starter failed on my 2003 Mini Cooper s. I replaced starter, did not fix, replaced plugs, wires, coil, battery, coil wire pig tail, and checked all fuses, all relays. Then sent it to and Indy shop we’re they did all the same test I did again including fuel pressure, pump, leak down, compression, was told everything checked out but they thought maybe computer. Sent to mini dealership where they charged me a lot of money to get me no further then I was, and they thought maybe dme, so I sent the dme away to be fixed. They said that there was a blown transistor or something like that. Put dme back in and still nothing. No spark still getting p2301 and P2304. I’ve been reading other post about similar issues and some have no conclusion some have what I’ve already done. Really need help at my wits end with all this .
Old Nov 3, 2018 | 10:28 AM
Revevsi's Avatar
Revevsi
Forgot to mention replaced crank sensor too.
Old Nov 3, 2018 | 01:05 PM
Minidogger's Avatar
Minidogger
I would have the DME retested, since it was bad before. Maybe there is a shorted wire that 'blew' the transistor & did it again.
Old Nov 3, 2018 | 01:35 PM
Revevsi's Avatar
Revevsi
It was at mini dealership for about a month and they check all wiring grounds everything and fix or repaired everything they found faulty. The key is chiming right, but could there still be a key ews problem? Or a software problem? I have the service engine soon light on as well as Mel light and traction control light on.
Old Nov 3, 2018 | 01:37 PM
Revevsi's Avatar
Revevsi
I’m working on getting the company that fixed the computer to give my money back and do what I should have done in the first place and send it to rpm.
Old Nov 4, 2018 | 11:29 AM
Revevsi's Avatar
Revevsi
Any help at this point would be very appreciated! Running low on my own personal knowledge.
Old Nov 4, 2018 | 01:48 PM
MVPeters's Avatar
MVPeters
If the Mini dealer couldn't fix it in a month, I can't imagine what the problem might be, but
do you have a different key to try?
or
there's a key re-learn sequence, as if you had changed the fob battery - might be worth a shot.
Old Dec 1, 2018 | 07:17 PM
Revevsi's Avatar
Revevsi
What is this relearn sequence? I only have one key, company refunded my money after fixing a blown transistor, but car still has no spark and still base code p2301 and p2304. Could clutch switch cause no spark, low tranny fluid? Or should I try and send my key, Wes, and computer to rpm?
Old Dec 4, 2018 | 06:00 AM
Revevsi's Avatar
Revevsi
So I have done more research and found out there is an inertia switch in the early minis, I don’t not have the switch and I do more reading and found out they incorporated it into the srs in the later models, on of my fuses are blown but my starter do burn up and I needed to replace it, know it cranks but won’t start. I was hit the day before it died right passenger side door. Started the car once after being hit and drove about a mile then started burnt up and and shut the car off. Is there a code for srs? Car has been down for almost 6 months any help would be great. Had dme repaired because that’s what the dealership said the next step would be to replace it but I don’t have $2600 to drop on it.
Old Nov 6, 2020 | 12:04 PM
Keaton Waldo's Avatar
Keaton Waldo
Please tell me you figured it out. I’m having the EXACT same issue with my 2003 R53. Help :(
charrigan
Jan 30, 2022 01:48 PM
Shen456
Jun 15, 2021 03:51 PM
2004JBMINI
Jul 2, 2012 12:02 PM
rawcapture
Aug 14, 2009 03:30 AM
