battery crazy sparking when connected
Old Aug 16, 2018 | 08:01 PM
MINI1342's Avatar
MINI1342
2002 R53; Just replaced engine.
I am getting terrible sparks when trying to connect the battery and everything is consequently dead.
The engine was taken out by someone else so my guess is the starter connections are in question.
1. How many wires should connect the the starter?
- I have two large cables and one small one. The two are a cable from the battery positive, connected to the same post as a cable from the positive jump start stud under hood with the last cable being connected to the starter solenoid.
2. The starter shield is NOT shorting out on the positive studs.
What could this be?
I used a DMM and sure enough my pos and neg are shorted (likely misconnected) somewhere.
Ideas?
Thanks.
Old Aug 16, 2018 | 08:36 PM
Tgriffithjr's Avatar
Tgriffithjr
When you say terrible sparks are you talking about when you first touch the cable to the battery or are you gettIng sparks somewhere after the cable is on the post? You just put the engine back in. Could you have crushed a wire that is now grounding somewhere? Is everything dead when the battery is connected or because the battery is disconnected? If it was sparking after connection I assume that you immediately disconnected it? Need more info.
Old Aug 16, 2018 | 08:46 PM
MINI1342's Avatar
MINI1342
Sparking upon connecting battery
The battery has been full charged out of the car and upon installation (put positive on first, then negative) as soon as the negative just touches the battery I get HUGE nasty sparks.
I took a DMM and confirmed the positive jump start stud under hood is shorted (has continuity) to the Negative frame rail ground.
I suspect the problem is a connection.
I "installed" my engine (someone else removed it) hence it is potential that a cable is hooked up wrong.
Therefore, how many wires connect to the starter and where?
I placed two cables (one from battery and one from jump start stud) to the a single stud on the starter. A third smaller wire to the starter solenoid.
No, I do not have a pdf of the battery cable routing so if anyone has that, it would help me.
I am basically making connections blind.
Old Aug 16, 2018 | 09:26 PM
FlyByMike's Avatar
FlyByMike
I'd start by looking here. They have intricate wiring diagrams even if though the site navigation is a bit strange or arcane it is complete. https://www.newtis.info/tisv2/a/en/r53-cooper-s-hat/
-Mike
Old Aug 17, 2018 | 06:15 AM
Tgriffithjr
Should only be two connections on the starter; positive power and solenoid connection. Sounds like you might have an extra cable/wire connected.
Old Aug 17, 2018 | 07:56 AM
MINI1342's Avatar
MINI1342
So likely the other wire is ground. Does anyone have documentation or sketch?
So, I assume battery positive goes to starter and then solenoid wire. The third wire has to be a ground. Only question though, it is a rather short cable (about 1.5 feet long). I routed it from the jump start (pos stud) to the starter.
A drawing or sketch would be ideal and I can follow it through.
Old Aug 17, 2018 | 08:47 AM
MINI1342's Avatar
MINI1342
diagrams
I am using realoem (website) to help me identify. The guy that pulled the engine tore everything out including the engine harness. If anyone has a sketch or their own diagram, feel free to post. It sounds I have cable connected where it shouldn't be.
Old Aug 17, 2018 | 09:02 AM
Tgriffithjr
Did you try disconnecting the cable from the jumpstart post to see if that eliminates the problem?
Old Aug 17, 2018 | 09:05 AM
AoxoMoxoA's Avatar
AoxoMoxoA
There's a photo on Pelican's clutch replacement tutorial which shows the starter wired properly.
Looks like the short wire from starter motor to solenoid is at the right of photo.
Hope this helps.
Old Aug 17, 2018 | 09:21 AM
MINI1342's Avatar
MINI1342
Yes, disconnecting the 1.5' long cable does work. Just need to figure out where it is supposed to go. (From to). I assume it is a ground.
Old Aug 19, 2018 | 06:41 PM
Tgriffithjr
Did you figure this out?
Old Aug 19, 2018 | 06:42 PM
MINI1342's Avatar
MINI1342
Got it.
It was the small wire on the starter contacting the starter shield.
Old Aug 19, 2018 | 07:15 PM
Tgriffithjr
Got it.
thanks for the info. It’s almost always the simplest answer!
cargod4490
Nov 8, 2012 12:49 PM
Midnight Blue
20
Feb 28, 2011 03:10 PM
bustadons
Jan 21, 2011 08:00 PM
chico8084
Jul 31, 2009 12:13 PM
