Speedometer
Old Jul 14, 2018 | 04:55 AM
Ankersen21's Avatar
Ankersen21
Speedometer
Hi guys! I have a 2004 Mini Cooper R50 and my speedometer needle is stuck at 0. Maybe the needle got pushed in I’m not sure but I’m looking at getting a new speedometer but I want to know before buying one if I will need to reprogram my mini or do anything else the “might” require a dealership or something. Thanks a lot guys!
Old Jul 14, 2018 | 11:21 AM
RB-MINI's Avatar
RB-MINI
Do you have the big speedo in the middle, or on the steering column with the tach? The big one in the middle will cost a lot of $$$ and require dealer programming, unless you know someone extremely knowledgeable with this, and has the right programming software.
The center clusters (speedo, NAV, or Chrono gauge pack) are programmed with the VIN and options, and also keep track of the mileage of the car. The VIN is permanently burned in and the mileage can’t be changed to match your car. If you somehow get a used one to work, your car will now show the mileage of the donor car. If you get a new speedo it will have to be coded with your VIN and options and will start from zero.
The programmed options control the warning lights on the column gauges. If you get a used center cluster with different options, your column lights might not light up correctly.
Hopefully your issue is with a column mounted speedo which should be plug and play as long as they’re the same.
Old Jul 14, 2018 | 02:42 PM
rkw's Avatar
rkw
Do you mean the needle is physically stuck, or it moves freely but doesn't operate?
Old Jul 14, 2018 | 02:55 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues section.
NUMMYTIME
60
Apr 22, 2003 12:20 AM
MINIACK
Jan 31, 2003 08:38 PM
dwathen
Jan 5, 2003 07:16 PM
chrisneal
18
Oct 19, 2002 09:38 PM
Joel
Sep 18, 2002 07:41 PM
