Anyone tried AC Pro?
Old Jul 13, 2018 | 11:13 AM
Drumsound's Avatar
Drumsound
Hello all,
My '06 MCS doesn't push out the coldest air, and it takes a while before it makes any difference. I was thinking of trying AC Pro from the auto parts store.
Has anyone here used it, was it effective?
Thanks!
Old Jul 13, 2018 | 05:19 PM
Whine not Walnuts's Avatar
Whine not Walnuts
AC Pro works but the bigger question is whether you have hooked up any gauges and figured out what you have. Item # 20 in the below thread has some good info on the AC system.
https://www.northamericanmotoring.co...questions.html
Old Jul 14, 2018 | 03:23 PM
Drumsound's Avatar
Drumsound
Thanks, man.
Old Jul 14, 2018 | 06:34 PM
Filmy's Avatar
Filmy
If AC Pro is a DIY A/C recharge kit, just remember to not overcharge your system with refrigerant. The system will take the overcharge, but then not work. Buy or use some real gauges to be sure.
Old Jul 14, 2018 | 09:38 PM
OCR's Avatar
OCR
I used it about 3 weeks back on my 05, S.
Worked fine in my case. As noted above, no matter how much I "tried...!" to get the pressure a little higher, apparently the pressure in the can would not overcome the pressure in the cars system, and about the center of the "green" area on the gage (don't recall the actual pressure).
Also, in my case, the system took a very little additional refrigerant/pressure to work well, less than half a can. I feel cheated...payed good money for the damn can..!
Mike
Old Jul 17, 2018 | 08:19 PM
Tgriffithjr's Avatar
Tgriffithjr
Get a set of gauges from harbor freight for about $40. It’s too easy to overcharge your system without knowing pressure readings which are based on ambient temperature. You can blow your compressor easier than you think by overcharging. Besides, r134a is only about $5 a can if you go the gauge route.
Drumsound
Jun 22, 2017 07:45 AM
Eastcoast-S
Jun 6, 2003 08:34 PM
Splakehunter
Mar 24, 2003 08:46 AM
Nomonstersinme
Feb 1, 2003 08:24 AM
