How cold is your AC?
Old Jun 28, 2018 | 01:45 PM
Solamar's Avatar
Solamar
2002 MCS with ~50k miles
My AC blows cool air but is not really capable of cooling down the entire cabin. I drove down to the desert last week, 108* outside, AC was better than nothing but I was still sweating.
Both of my other cars (newer Toyotas) can freeze you out if you keep the AC on high...
Is this typical for Minis? Or should I check my AC charge? FWIW I just changed the cab air filter.
Old Jun 28, 2018 | 03:10 PM
Capt_bj's Avatar
Capt_bj
2002?
I think a system check is not out of line .....
I tend to have mine checked every 2 years - car and home - and for some reason my home system works fine altho my neighbors (all homes built around the same time) all seem to be replacing their a/c systems .....
Old Jun 28, 2018 | 04:05 PM
bee1000n's Avatar
bee1000n
Mine (04 MCS) is the same as yours. I don't remember it being able to get the cabin cool with temps over ~85 degrees even when new. Using recirc helps. I'd get yours checked out, just in case it could be better.
Old Jun 28, 2018 | 08:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With it being a 2002 it is a good idea to have an evac and recharge done as it likely is a little low just due to how old it is.
Here are a few things we do here in Hotlanta
1. when I recharge the system I overcharge it just like .1-.2lbs giving it a little more pressure
2. install a radiator air diverter as it makes the condenser more efficient.
https://www.waymotorworks.com/fiberg...-diverter.html
3. Can use a 2% larger ATI damper. This gives you just a little more RPM on the compressor at idle in traffic making it work just a little better.
https://www.waymotorworks.com/super-...ulley-r53.html
4. run it on recycle as it will work better too.
Old Jun 29, 2018 | 12:59 AM
DeadErnie's Avatar
DeadErnie
My air blows pretty cool but one thing that made a big difference was buying the sun shade that suction cups into the sunroof.
Old Jun 29, 2018 | 05:40 AM
ProjectMini's Avatar
ProjectMini
Hard Nips in the R60 2011
That being said I have acrylic tinted windows as well.
Long commute, Hot area. Regularly in the 90s.
Old Jun 29, 2018 | 05:55 AM
ag13's Avatar
ag13
My 19, f56 is pretty good with the air. My issue is that the vent on the top of the dashboard seems always on and most of the air goes out that vent, no matter what setting I’m on.
Old Jun 29, 2018 | 06:28 AM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
I have a 2002 MCS with 170k on it. My AC has always been that way. I live in the south east and Unless I am on the highway I have to have the AC on high and on recirculate. I don't know if you have tented windows but that really helps.
Old Jun 29, 2018 | 08:13 AM
Solamar's Avatar
Solamar
Thanks for the feedback! Sounds like an AC service is probably a good idea, but don't expect a winter wonderland in the desert...
Old Jun 29, 2018 | 08:19 AM
Solamar's Avatar
Solamar
Thanks for the info.
On my short list of preventative maintenance is to replace all the wear items on the drive belt side at the same time as adding a 15-17% SC pulley.
- Tensioner
- Damper pulley
- Belt
- idler pulley (do these ever fail??)
I was wondering about the 2% Damper + 15% SC pulley combo instead of the 17% SC pulley. Sounds like the 2% might be a win/win.
Old Jul 6, 2018 | 01:23 PM
suspencer's Avatar
suspencer
- Tensioner
- Damper pulley
- Belt
I would definitely do the idler pulley too, while you're in there. It's cheap and easy to replace. I replaced my belt tensioner, crank pulley, and alternator a while back, and soon afterwards my idler pulley fell off while cruising down the interstate. Belt got chewed up good and coolant expansion tank spewed everywhere. Don't make the same mistake I did!
Old Jul 6, 2018 | 08:27 PM
BeardedForever's Avatar
BeardedForever
I have a thermometer in my vents to keep an eye on my a/c. It blows as low as 58*F with a good amount of air going over the condenser.
Old Jul 7, 2018 | 08:20 AM
gsfent's Avatar
gsfent
I do also. Driver's right vent.
My R52 will get down to about 42-43F. Rarely run more than #2 on fan speed. Temp on low. Outside air.
Regards,
Jerry
Old Jul 18, 2018 | 08:02 AM
Tgriffithjr's Avatar
Tgriffithjr
When checking the temp at the vent keep in mind that the lower the outside temp the lower the vent temp will be. R134a will get you about 40-45 degrees cooler than ambient air temp. So, the hotter it is the higher the AC temp will be. On a 100 degree day, 55 is a good inside temp, give or take. Be sure not to overcharge the system; it’s notbthat hard to blow a compressor especially when it’s hot outside. The higher the temperature outside the higher the pressure in the system. Find an ambient temperature/pressure chart for r134a. A cheap set of gauges is about $40 at harbor freight. R134a is about $5 can at Wally World, which is cheaper than the $20 you pay for the do-it-yourself can with hose and gauge attached. The gauges will pay for themselves after a couple of cars, will ensure that you don’t blow your system, and make you a better mechanic. Your friends will like you too when you help them get cool!
savilrg
Feb 12, 2008 01:45 PM
chrisneal
Detailing 101
25
Jan 8, 2007 12:06 PM
NMgokart
Tires, Wheels, & Brakes
Dec 1, 2006 08:40 PM
savage65
38
Dec 5, 2004 11:57 AM
