Power sockets shorting out, blowing fuses.
Old May 31, 2018 | 04:53 PM
cavaliers60's Avatar
cavaliers60
I’m having a slight issue with the power sockets in my mini. I’ve replaced the fuse, but when the mini gets turned to the on position, I see the fuse blow out. Nothing is plugged in so I know it’s a short somewhere. Just curious if there is anyone who had the same issue before and has a good idea where to look for the potential short.
Old Jun 1, 2018 | 04:59 AM
Capt_bj's Avatar
Capt_bj
I'd start with the socket up front. From the stress of plugging various chargers in and out the plastic tabs of mine broke allowing the socket to turn. I could see how the wires could get broken or crossed ....
btw, as I recall the rear socket was on a different fuse on my 02 . . .
Old Jun 2, 2018 | 04:40 PM
Eric_Rowland's Avatar
Eric_Rowland
Start at the socket itself - that's the most likely place.
Old Jun 3, 2018 | 07:05 AM
S-2013's Avatar
S-2013
Yeah, replace the whole socket. I was having similar issues with my R56 and ended up replacing the socket with one of these:
Old Jun 3, 2018 | 08:27 AM
cavaliers60
Cool, I’ll do that and see if it fixes it. I had a hunch it was the socket itself. I replaced the fuse once and it didn’t blow right away. Worked ok and when I moved the center console that it’s seated in, it blew the fuse. So I suspect it’s the connection right there.
Old Jun 4, 2018 | 03:42 PM
cavaliers60
So, turns out, everything is fine. I started to take the old outlet out and noticed that there was a penny shoved in the socket. It was what was causing the short.
so, removed the penny and all is working fine now.
Old Jun 5, 2018 | 11:15 AM
Eric_Rowland
That would do it...
JFalcon
Electrical
May 17, 2011 09:58 PM
jjamie99515
Apr 13, 2011 02:58 PM
DrQuasar
Electrical
Nov 24, 2010 06:22 PM
05DSMCS
Dec 15, 2006 03:04 PM
bglct99
Sep 7, 2006 10:17 AM
