Electrical woes - need advice.
Old Apr 18, 2018 | 12:16 PM
JAB 67's Avatar
JAB 67
2004 MCS; 150K; battery new 4 months ago; original alternator; new pulley tensioner and belt; new idler; ATI crank damper several years ago.
Today I drove about 15 miles to run an errand. On my return I stopped for a burger. Upon restarting the car I sensed that the power steering pump wasn't working, but a moment later it came on and all was well, or so I thought. I drove off. A few minutes later I realized that the battery light was on. The power steering was working, and there were no other indicators. I drove the remaining 5 miles home with no problem. Shut the car off and inspected the engine bay but all looked well. Car restarted with no problem but battery light still on. However, no power steering assist. Pump was replaced several years ago under the recall.
Thoughts? TIA.
Old Apr 18, 2018 | 02:04 PM
JAB 67's Avatar
JAB 67
I suspect that it is the alternator voltage regulator. Is that easily replaced without removing the alternator from the car?
Old Apr 18, 2018 | 03:05 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Thoughts? TIA.
It is likely the alternator brushes are worn to a point that now barely making contact with the slip ring commutator. It starts as intermittent no charge. Power steering requires the alternator charging to function. I suggest you look into replacing the alternator.
Old Apr 18, 2018 | 03:17 PM
JAB 67's Avatar
JAB 67
Makes sense. I may have a good used voltage regulator on the shelf. Is it possible to change the regulator without removing the alternator from the car? If not then yes I will replace the entire alternator. Thanks.
Old Apr 18, 2018 | 03:34 PM
pnwR53S's Avatar
pnwR53S
It have been eons since I worked on an alternator problem that I forgot with most modern cars the brushes are a part of the regulator.
When you have the worn regulator out, I suggest visually inspect the copper slip rings. More likely than not they should be fine.
Old Apr 18, 2018 | 04:47 PM
JAB 67's Avatar
JAB 67
Thanks again. Any idea whether I can R&R the regulator with the alternator in the car?
Old Apr 18, 2018 | 05:02 PM
pnwR53S's Avatar
pnwR53S
Sorry. Zero experience with the alternator in MCS. Mine still has many miles to go before it sleeps.
Old Apr 18, 2018 | 05:07 PM
pnwR53S's Avatar
pnwR53S
If you look carefully at the (supersized) photos here that will give you some idea how feasible.
Old Apr 18, 2018 | 05:58 PM
JAB 67's Avatar
JAB 67
thanks.
Old Apr 21, 2018 | 07:04 AM
Zsm's Avatar
Zsm
Unfortunately, you cannot get to the regulator without taking the alternator out.
Its not a bad job. You will need to put car into service mode and then you can R&R the alt.
Rock Auto apparently has a reliable new unit for a good price.
We had to gamble on an O’Reilly unit. First lasted two weeks. Current one going 18 months. Can say hit and miss quality?
Old Apr 21, 2018 | 02:16 PM
JAB 67's Avatar
JAB 67
I have a new alternator on the way. Yes, I concluded that it was not possible to install the regulator in the alternator without removing the alternator from the car.
malibujoey
Oct 14, 2016 06:28 PM
bavmotors
Dec 10, 2015 03:01 PM
goblue96
Jun 28, 2012 09:39 AM
Jhud
Jan 27, 2009 09:13 AM
