Cruise Control N0t working
Old Apr 12, 2018 | 08:17 PM
freddmc's Avatar
freddmc
I bought a 2002 mini with 73000 miles on it. The cruise control does not work. When I press the button to engage cc a light on the instrument panel flashes momentarily but it does not work.
Is there something obvious I should look for i.e. blown fuse, or is this a more compllcated problem,.
Fred
Old Apr 13, 2018 | 04:56 AM
Whine not Walnuts's Avatar
Whine not Walnuts
You have a sunroof?
Wondering whether the circuits of the cruise buttons on the steering column go through the BCM. The BCM is in the passenger side foot well and if the sunroof drain tubes get plugged the BCM can get wet.
Old Apr 13, 2018 | 07:31 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Just a dart to the board. I would check the (cancel) switch on the clutch pedal first. Cruise control involves the throttle, speed sensor so most of the work is done by the DME. The brake switch also cancel the cruise, but I suspect it shares with brake lights.
Old Apr 13, 2018 | 07:44 AM
pnwR53S's Avatar
pnwR53S
cruise control wiring
Here is the wiring diagram of CC from 2006 Mini. Earlier models should be very similar, except may be fuse numbers. I would not count on fixing the issue with simple fuse replacement. All the work is done by the DME, may be with the exception of the UI of the multifunction steering wheel's buttons control.
Check the brake and clutch switches first.
Old Apr 13, 2018 | 10:17 AM
djohnson34's Avatar
djohnson34
When it happened to me it was the wheel speed sensors. If your traction control, and abs lights are on that could be the culprit.
Old Apr 13, 2018 | 10:33 AM
jamez's Avatar
jamez
I have the same curious problem.
I've swapped out the Clutch Switch, same result. Though occasionally in my scans it tells me the clutch sensor is not working. I have a feeling in my case it may be a wire or connection somewhere up the line.
No other lights on.
Old Apr 17, 2018 | 08:57 PM
DamnCampers's Avatar
DamnCampers
Do you know if the transmission has been swapped out? I remember reading that if you did the retro fit for cruise control that it needs the be coded. Here is a link talking about the refit
http://www.minitorque.com/forum/f845...tml#post118862
It might be worth going to the link and reading to see if any of it applies.
sailesh
Apr 8, 2014 02:51 AM
jsnake77
Nov 22, 2010 06:58 PM
drnick
Jul 16, 2003 11:47 AM
