2006 Mini Cooper TPMS and dcs lights
Old Apr 17, 2018 | 05:00 PM
Castoracing's Avatar
Castoracing
1st time mini owner.
Glad I found this site.
Tire pressure light and traction light will not go out. Vehicle seems fine besides the lights staying on. Any help? I don’t think speed sensor because no abs light.
I have a weird creek sound when turning going slow, like pulling in a parking spot.
One more thing, next to the air box there are 2 hoses part of cooling system maybe to the heater core? Anyway where the hoses connect there is something that looks like a bleeder or something on top have a small leak there.
Old Apr 17, 2018 | 08:39 PM
RogueMini's Avatar
RogueMini
The tire pressure and dsc lights are likely due to an abs sensor that has gone bad. it could be other things, but theabs sensor is most likely; otherwise you need to have the error codes pulled to see if it is something else. change the front drivers side ABS sensor with a VDO or an OEM one.
welcome to NAM!
Old Apr 18, 2018 | 04:41 AM
Castoracing
Thank you I am going to order a new speed sensor. Just curious why you would think it’s front driver side?
Old Apr 18, 2018 | 09:44 AM
RogueMini's Avatar
RogueMini
its the one that failed on my car; my MINI guy says its the only one he’s ever had to replace on customer cars. dont do what i did and cheap out on the sensor like i did: i bought one made by “vemo”. It cleared the dash lights, but wreaks havoc with the traction control. VDO makes the MINI one, i still have to get me one....
There are other things that can cause the tpms/dsc and sometime abs lights besides an abs sensor; if you dont want to guess and “throw parts at it”, have a good MINI shop pull the codes and identify exactly which sensor has failed. Your choice. good luck.
Sidewalksam
Jun 1, 2015 01:16 PM
louie12345
May 24, 2014 04:16 AM
syfted
Aug 4, 2008 12:39 PM
MarioKart
Nov 9, 2006 07:47 AM
