Crank Sensor O Ring
Old Apr 8, 2018 | 02:49 PM
MiniSMan's Avatar
MiniSMan
Crank Sensor O Ring
Is it possible to get to the Crank Sensor to replace the O ring from the top of the car if i remove the throttle Body and remove the plastic air filter tube ? I think i have enough room to do it blind without putting the car in Service mode ....Is it doable?
Old Apr 8, 2018 | 04:39 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I have read something somewhere that is is possible but I just cannot remember where nor all the details. I will try some searches.
Old Apr 8, 2018 | 04:47 PM
Whine not Walnuts
On the justa, you can reach without removing a bunch of stuff, on the S you can loosen a lower motor mount and then use a ratchet strap to pull the engine back so you can get you hands in there, but getting the plug off can be daunting.
https://www.northamericanmotoring.co...on-sensor.html
Old Apr 8, 2018 | 05:15 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
JMHO, but putting into service mode will only take 1/2 hour at most and give you access to do a good job w/o contortions. Who knows what other stuff you might find that needs doing?
Old Apr 8, 2018 | 05:29 PM
gumbedamit's Avatar
gumbedamit
+1
I've gotten it down to under 30 mins, and that includes putting the car up on jack stands.
Old Apr 8, 2018 | 05:55 PM
Whine not Walnuts
Has the water pump ever been replaced?
Old Apr 8, 2018 | 06:01 PM
MiniSMan's Avatar
MiniSMan
Original Water pump ...my 06 has only 73,000 miles .... when should the water pump be replaced ? I just did the serpentine belt at 60,000 miles last summer ....
Old Apr 8, 2018 | 07:40 PM
CRC's Avatar
CRC
After you have replaced the o-ring, use some red RTV sealant on the sensor flange as the o-ring will leak again.
Old Apr 9, 2018 | 04:51 AM
Whine not Walnuts
Many say waterpump has seen better days after 70,000 miles.
AvianMan
Mar 30, 2020 07:12 AM
ACEkraut11
Dec 3, 2015 01:13 PM
purplehaze05mcs
Jul 22, 2013 05:41 PM
JAB 67
Jun 24, 2011 01:04 PM
MINIsurf
Mar 29, 2010 01:11 PM
