2009 R56 Cooper non-S - oil leaking part - what does this do?
Old Apr 8, 2018 | 11:07 AM
kurtsunn's Avatar
kurtsunn
Does anyone know what this part is and what it does? (the aluminum part above the oil filter cover) (see photos) Is it known to leak oil? As you may be able to see in the photos ... oil leaks out of this part and then travels down the black cable harness and oil has been pooling around the blue harness connector below. Any suggestions? What is this part? Should I replace it?
I've been having a burning oil smell issue and hope this may be the culprit ...
Attached Thumbnails 2009 R56 Cooper non-S - oil leaking part - what does this do?-img_1995.jpg   2009 R56 Cooper non-S - oil leaking part - what does this do?-img_1996.jpg
Old Apr 8, 2018 | 12:59 PM
scott13's Avatar
scott13
That is the vacuum pump. Mine is leaking oil too. There is an o-ring between the pump and the engine that costs about $5.00. An easy repair. Some people are deciding to replace the entire pump as a precaution. I haven't decided which way to go yet on my low-mileage MINI.
Old Apr 8, 2018 | 03:31 PM
kurtsunn's Avatar
kurtsunn
Thanks for the info. Looks like a job I could tackle myself and try to replace the O-ring.
Old Dec 22, 2021 | 09:38 PM
scott13's Avatar
scott13
Update. I replaced the O-ring between the vacuum pump and the engine but that did not fix the leak. I wound up replacing the vacuum pump and that solved the problem. Just recently I replaced the gaskets on the oil filter housing which is another common source of oil leaking down the front of the engine.
kurtsunn
Jun 18, 2018 07:05 AM
Matthew Hardesty
May 18, 2017 11:00 AM
PanchoS
R55 :: Clubman Talk (2008+)
Mar 29, 2017 10:36 PM
lasher10
Apr 23, 2016 12:41 PM
zuyzuy
Jan 16, 2014 01:27 PM
