Strange AC problem
Strange AC problem
I drove the car to the store yesterday and I was there for about 2hours . On the way ther the AC functioned 100% perfect but upon restarting the car the AC now blows hot . The blower motor is working and the AC on light is lit but no compressor engagement . Any ideas ??
Is there an easy way to energize the clutch to see if it works .
We used to jump out the low pressure switch in the old days to see if the low pressure sw was bad or the system was low . Wheres the low press sw on the mini
and thanks for the help
I jumped terminal 30 and 87 of the relay and I dont think the clutch is comming on however term 87 and ground is not open as a bad clutch would indicate . So I guess its to the shop for a diagnoses
So heres an update . Relay ,fuse ,are good . I connected a guage to the low side and there seems to be sufficient freon (90 psi) . I measure the clutch resistance thru the relay socket and its not open . I did notice that the low speed fan is not comming on but I bought the car used and never noticed if it ever did ,HOWEVER the I have noticed that when I shut off the car the high speed fan will sometimes continue to run like its trying to prevent an overheat .
Do you think this is causing my ac issues
Is it ok to bypass the low speed resistor with a solid wire so the fan runs on high always
I bypassed the relays for low and high speed cooling fan and both work . Then I switched relays around to be sure the relay was good . Its not the low speed fan for sure . I would say its the clutch but as I said I see resistance when I ck the clutch thru the relay
HighSchoolzMINI
15
Oct 21, 2006 10:47 AM
cmyk
26
Jun 5, 2006 09:57 AM
Navigation & Audio Strange problem with Aux Items plugged into Ciggerate Lighter...
Pat_Cooper
Jan 6, 2006 12:20 AM
Yucca Patrol
19
Mar 22, 2005 11:05 PM
