Getting these codes
Old Mar 20, 2018 | 03:56 PM
dwilsonfl's Avatar
dwilsonfl
Getting these codes
codes: fuel volume P02; P0137 Oxygen sensor low voltage.
any ideas? About to start getting to a maintenance baseline with my Mini.
David Wilson
2005 R52
Old Mar 20, 2018 | 04:13 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues section.
Old Mar 20, 2018 | 04:17 PM
jasonp's Avatar
jasonp
David Wilson
2005 R52
So p0137 What happening is the o2 sensor is telling the ecm that the engine is running lean. and is probably causing your Po2 code. check for leaks on you manifold before leaping into a o2 sensor.
osnapcoopertime
R60/R61 Stock Problems/Issues
Jan 27, 2018 05:40 PM
nicknack
Dec 29, 2017 03:55 PM
ultrahuck
R55 :: Clubman Talk (2008+)
11
Jan 29, 2016 05:32 AM
ramtour2
Jun 1, 2015 11:49 AM
ridler
Jun 28, 2011 09:36 AM
