LDP cel codes, help run through the possible solutions?
Old Mar 18, 2018 | 02:59 PM
nismo4life's Avatar
nismo4life
So car in question is a 2005 R53 with about 120k on it. CEL came on last year (P1477 + P2400), and I already went ahead and checked the wires on the control arm. They were in fact pinched, shorting, and corroded. I cleaned them up, insulated them and the lights are still on after that. Next course of action I'm unsure where to go with.
Originally Posted by Aspen
To recap start with:
gas cap
evap valve
vac lines in engine bay
vac lines near charcoal canister and LD pump
LD pump
canister
This is what I found someone day previously. What I'd like to do is find a way to bench test the LDP to rule that out. I'd also like to test the wiring, does anyone by chance happen to have a pin out or schematic of here the LDP plug wires go to so I can check for continuity and resistance?
Gas cap was replaced previously as well. I am not getting the gas cap light on the dash, so I assume that's not the issue.
freestylin599
Mar 29, 2016 10:23 PM
dinanminicooper
Dec 8, 2010 01:09 PM
lawrie
Sep 2, 2010 02:11 AM
chakraj
May 25, 2008 01:03 PM
