DSS CV Axle- How do you get the lock ring back on?
I don't think it's gonna fit...
So I'm replacing the CV axles on my '04 R50. The passenger side has a bearing to hang the longer axle, and I couldn't find a new part that had the hanger attached. No problem, because there's just a little lock ring you pull out and then tap it off with a hammer, right?
Well, spent an awful long time getting it all apart. Trying to get the lock ring around the new one, but it's quite a big bigger than the old one. Ran my caliper just to be sure... diameter on the original shaft where you put the lock ring around is 35 mm. The new one is 50 mm!
It's a new axle made by some company called DSS and sold by a reputable supplier of MINI parts.
Any tips? Do I need to just muscle it over, somehow? Has anybody done this before?
Thanks,
Dave
You will have to flex one side of the clip on while twisting it onto the shaft. You will most likely deform the ring a little in the middle due to the flex, but nothing that can't be fixed. Make sure the mount is seated as far down as it should be and the ring will slip in with less effort then it took getting it off. When the clip is seated there will be some play in it.
I thought of one more thing I'm going to try this morning before I try to brute force it on there. There's another lock ring on the other side of the bearing. If I can get that off and slide the bearing down over the narrower part of the shaft, I should be able to get the big lock ring on easily.
I'll let you know how that goes...
Well, as much as I was hoping to find an easier way, it was brute force that won the day.
I used a couple of long screwdrivers wedged against the axle to spread the ring open wide enough to pull over the axle. It didn't seem to deform the ring permanently at all.
The snap ring on the other side of the bearing came off easily enough, but the bearing didn't move when I asked politely with my hammer, and I didn't want to push it too hard since it'd already been through a lot getting the carrier bracket on and back off again.
Good luck and my sincerest sympathy to anyone else who attempts this job. It ain't pretty, but it did work, and Ollie is back on the road now. The new bearing didn't spin quite as freely as the original, and might be howling a little at high speed, but I'm guessing it just needs to break in a little.
jetsr6
Jun 2, 2021 08:19 PM
AvianMan
Mar 30, 2020 07:12 AM
FSP / DSP (Street Prepared) MINIs Go 1-2-3 In DSS (aka DSP) @ Canadian Autoslalom Championships
JCWCOMP62
SCCA Solo and ProSolo
Oct 6, 2008 05:04 PM
