Turbo oil leak
Old Jan 26, 2018 | 06:18 PM
JCC9's Avatar
JCC9
Turbo oil leak
I have notice that car is leaking a good amount of oil from the turbo. I'm not sure where exactly the leak starts. From what I heard and read it seems like I need to replace the turbo part, but I've also saw something about an oil supply pipe. How can i know what needs replacing( sorry don't know anything about cars)
Old Jan 26, 2018 | 06:47 PM
BeardedForever's Avatar
BeardedForever
Look at the top of the turbo where the oil line connects. If it's has oil try replacing the line.
Old Jan 27, 2018 | 02:47 PM
MiniCooper_S's Avatar
MiniCooper_S
Take it to a bmw/mini shop and ask to have your turbo oil feed line replaced. Should cost anywhere from $500-$1000 depending on the shop.
Old Jan 29, 2018 | 12:15 PM
Here is all the info on the turbo oil lines. Read this is goes through all the thing to look for and parts you need. If you cant do it yourself you can show this to a local euro shop.
https://www.northamericanmotoring.co...-oil-line.html
Old Jan 29, 2018 | 02:19 PM
nkfry's Avatar
nkfry
There are a couple usual culprits for oil leaks in that area: the vacuum pump, turbo oil feed line, and the oil filter housing gasket. But as of the past year or so I've seen multiple cars with an oil leak from a galley plug behind the flywheel that could be mistaken as a filter housing leak.
I would recommend getting it diagnosed and looking into our TOL Super Kit, it uses a stainless braided line and MINI OE gaskets, and encompasses many of the failure points of that job.
I advise everyone against the MINI OE feed line as it's a garbage design that hasn't been revised and will only leak in the same fantastic fashion.
Detroit Tuned TOL Kit
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
quikdime
Jul 5, 2019 10:17 PM
vhsnap
Sep 3, 2017 04:24 PM
DRoc7822
Feb 15, 2016 12:47 PM
girubato1
Jan 26, 2015 09:48 AM
theimage
Jan 4, 2014 12:38 PM
