Oil Leak from Bell Housing
Old Dec 26, 2017 | 06:12 PM
jjcsnlynn's Avatar
jjcsnlynn
I replaced my engine last summer and installed a new rear main oil seal. I now have oil coming from the hole at the bottom of the bell housing but I am not sure it's engine oil.
The trans has 190K miles on it.
When I was at the dealer the other day they said my slave cylinder was leaking but I couldn't afford to get it replaced at their prices. The boot is deteriorate but I can't be sure it's leaking.
. I put synchromech oil in the trans.
So...my question is can a slave cylinder leak and run down inside the bell housing? If not, I probably have a bad input shaft seal on the trans.
I ordered a new slave of RA. I hope if fixes it.
Old Dec 26, 2017 | 06:21 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Brake fluid is water soluble and oil is not so it should be easy to tell one from the other.
Old Dec 27, 2017 | 05:05 AM
Whine not Walnuts's Avatar
Whine not Walnuts
The rear main seal replacement can be a issue and if not performed correctly, the seal will leak. They make UV light dyes.
Old Dec 27, 2017 | 11:38 AM
Rear main seal, then the seal on the bell housing behind the guide tube. The Slave can leak inside the bell but its brake fluid and with an easy examination or pop out the two bolts of the slave and check it really quick. Then you will know.
Main seal: 11111492244
Guide tube seal: 23117518633 smells like the funky trans fluid
https://www.northamericanmotoring.co...ts-needed.html
Old Dec 27, 2017 | 01:39 PM
Whine not Walnuts
ECS brought up the trannie fluid, and that stuff does have one odor that is not going to be confused with motor oil or brake fluid.
Old Mar 8, 2020 | 02:53 PM
booyah93's Avatar
booyah93
Whole doing my clutch I removed the bolts and tried to remove the bell housing which seemed to have a gasket squished between it and the clutch area. Where can I find a replacement gasket?
Old Mar 8, 2020 | 03:09 PM
jjcsnlynn's Avatar
jjcsnlynn
What gasket material? There isn’t any when doing a clutch. Your picture looks like a wire may have gotten pinched inside the bell housing.
Old Mar 9, 2020 | 05:56 AM
Yep, no gasket, my guess is a wire or something also.
Old Mar 9, 2020 | 05:58 AM
booyah93's Avatar
booyah93
Should I put RTV? That's what I saw someone else rebuilding the Midland did and I found something similar to RTV on the bolts I took out.
Old Mar 9, 2020 | 02:11 PM
booyah93's Avatar
booyah93
Also I will have the flywheel turned, but do I need to rough up the face with sand paper?
Old Mar 9, 2020 | 06:55 PM
booyah93's Avatar
booyah93
I'm having a hard time finding a new guide tube for my 02 - 04 R50 transmission
DRoc7822
Feb 15, 2016 12:47 PM
rickuski
Jul 28, 2013 11:41 AM
DOC4444
Aug 27, 2012 06:01 PM
TurboMini
Dec 3, 2009 01:05 PM
