Engine Light puzzle
Old Dec 9, 2017 | 08:26 AM
smith80678's Avatar
smith80678
Engine Light puzzle
Had the engine light come on and I took it to the dealer. Their test found fault code 2d22. They then replaced the oxygen sensor and charged me 500$ The engine light came back on as soon as I got in so I brought it back in. This time they found fault code 2bco and determined that the crankcase pressure was below specs. So they replaced the valve cover. The valve cover was just replaced 3 months ago so the parts were under warranty so I just had to pay 300$ As soon as I started driving the car the engine light came back on. Anyone have any idea what's going on? Should I keep throwing money at it? Thanks
Old Dec 9, 2017 | 10:38 AM
S-2013's Avatar
S-2013
Sorry i cant be of any help but here’s a rundown of most of the possible codes associated with BMW/Mini. Your second code, (2bco) lists the following suspected faults:
-Oxygen sensor before catalytic converter defective
- Mass-airflow sensor defective
- Defective injectors
- Intake-manifold pressure sensor defective - Intake-air temperature sensor defective - Camshaft position sensor defective
- Defect in high-pressure fuel system
- Defect in low-pressure fuel system
- Intake system leaking
- Oil cap not sealingh
Leak in exhaust system before oxygen sensor behind catalytic converter
- Poor-quality gasoline
They also state under service instruction to “delete mixture adaptation following repairs”. Maybe they forgot to do the above.
http://www.n54tech.com/flash_files/N55_codes.pdf
Old Dec 9, 2017 | 12:27 PM
smith80678's Avatar
smith80678
When and if the car stops working, the problem will be easier to detect?
Old Dec 9, 2017 | 06:03 PM
dube53's Avatar
dube53
How old is the car, mileage and year? Is it the N14 engine?
Old Dec 9, 2017 | 07:11 PM
smith80678's Avatar
smith80678
It is 2013 s coupe with 120,000 miles. N18 engine
Old Dec 9, 2017 | 07:39 PM
dube53's Avatar
dube53
I would give up and buy something else ....... it doesn't make sense to invest money at 120K.
Old Dec 9, 2017 | 08:54 PM
S-2013's Avatar
S-2013
Not everyone can afford or want a new car payment. My 2013 N18 has over 130,000 miles. Car is running great and it’s worth it to me to install a rebuilt turbo this Spring.
Old Dec 11, 2017 | 06:31 PM
dube53's Avatar
dube53
At so high mileage, something else is coming that will cost more than the car's worth. There is always a time to sell before these problems may happen and take advantage of the residual value.
This is certainly better than wasting money on costly repairs and expensive maintenance. Just my opinion
Old Dec 19, 2017 | 06:06 AM
smith80678's Avatar
smith80678
Update: Now the engine light tends to go on and off. I went in for my required emission testing and failed it. Engine light and mixture too lean.
Old Dec 19, 2017 | 10:20 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I'd be going back to the dealer and having a real blunt chat with the service supervisor. After two visits and $800, they owe you a fix.
Pull the latest codes and post here, maybe someone has some ideas.
Old Dec 20, 2017 | 01:37 PM
smith80678's Avatar
smith80678
They will just say it is other things and charge me. I think I am going to try this European auto Care place. I thought the dealer would have the best expertise but I was obviously wrong. The mechanics at the dealer are awfully young
Old Apr 25, 2018 | 06:22 AM
smith80678's Avatar
smith80678
Follow up:
So I took the vehicle to an independent Euro Auto Care place. The engine light code was p171, mixture too lean. They eventually figure out it was the fuel injectors we're clogged and needed to be replaced. So the dealer wasn't able to figure that out and replaced the valve cover by mistake. Total cost to me - 3500$
Old Apr 27, 2018 | 01:26 PM
beeniecmc777's Avatar
beeniecmc777
Similar issues
i have been having similar issues for THREE years. NO ONE can tell me what’s wrong. Latest code for my check engine light is because the CO2 sensors need to be replaced, but I have had both replaced. When taken to a Mini Dealer service department they said they couldn’t figure out why my car’s check engine light was on. So who knows how much $$, and a year and a half expired tags later, I am at a total loss as what to do next. And I have no money to get a new car.
Old Apr 27, 2018 | 03:53 PM
Minidogger's Avatar
Minidogger
You could buy a good scanner & that would tell you what codes are triggering the check engine light.
