supercharger noise
Old Nov 25, 2017 | 06:22 PM
torogi's Avatar
torogi
supercharger noise
Hello,
I have a 2006 MCS, recently I got a supercharger air leak so I brought it to my local shop. They did the smoke test and found the leak, and since they are pretty much taking out the SC, I had them service any part that needs to be serviced.
They changed;
SC intake air duct
Water pump
Serpentine belt
Belt tensioner (no tension)
3-pc radiator hose
Air duct gasket
Throttle body gasket
SC oil
Anyhoo, I was driving away and got this weird noise. 5th gear to 6th, and every time I am pressing gas on 6th running around 75-80.
On neurtal, it comes at around 3k.
Shifting from 1st to 2nd at 4k, this comes on too when I hit gas from there.
No SC whine that it used to have.
Clear, no codes.
TIA.
Old Nov 25, 2017 | 08:53 PM
RllyDrvrIX's Avatar
RllyDrvrIX
Bring it back, quickly. Something isn't right. I'm not going to guess, only suggest it goes back ASAP.
Old Nov 26, 2017 | 12:03 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I do not like attempting to diagnose a problem based on a video/sound clip taken from a distance. Based on what little to go by, I would suggest you look carefully at the possibility of a damaged (beyond serviceable) main crank pulley that is also a damper. The awful noise can be the steel pulley wobbling at speed and hitting the aluminum timing chain cover. Do a google image search and you will find some photos.
Old Nov 27, 2017 | 12:38 PM
torogi's Avatar
torogi
Dropped it off at the shop today. Initial diagnosis is air being pushed out somewhere. Maybe a loose gasket. Not the main crank pulley. Sound is coming from the left side (driver side).
I hope it would be just a gasket or seal :crossfingers
Old Nov 27, 2017 | 12:53 PM
pnwR53S's Avatar
pnwR53S
The gasket of what this big noise can come from is the intercooler rubber couplers. They are quite easy to check.
Old Nov 27, 2017 | 01:06 PM
My guess is its a cracked IC boot or its loose.
Old Nov 28, 2017 | 09:47 PM
torogi's Avatar
torogi
Ok, so I picked up the car today.
Apparently the BOV wasn't opening fully making that noise. They replaced it and now, just the hummm of the SC... :awesome
Thank you all for your input. I could have checked that part but since it was just recently serviced, i thought the BOV was checked. Oh well..
Old Nov 28, 2017 | 10:33 PM
pnwR53S's Avatar
pnwR53S
You sure had a BOV - Blown Open Valve instead of a BPV, and that explains all.
