mini cooper s access needed to change oil filter housing leak
Old Nov 22, 2017 | 12:09 AM
Wayne Soderberg's Avatar
Wayne Soderberg
2007 r56 oil leak front of engine 120000 km.
Do I need to remove the exhaust downpipe to remove the oil filter housing to replace the seals. Any advice would be appreciated. Regards Wayne
wayne.soderberg2@bigpond.com
Old Nov 22, 2017 | 04:53 AM
MiniToBe's Avatar
MiniToBe
you only need to move the coolant overfill tank to the side and just make room to pull the oil filter cap out.
Old Nov 24, 2017 | 11:27 AM
MiniCooper_S's Avatar
MiniCooper_S
you wouldn’t need to remove the downpipe but you would need to remove the turbo inlet, coolant reservoir, some vac lines and unhook some of the wiring harness to get the whole housing off for a gasket change.
Old Nov 24, 2017 | 06:01 PM
MiniToBe's Avatar
MiniToBe
oh shoot...this must've been my 100th post reply. I rushed to the answer without paying attention.
I think you might need to remove the turbo heat shield too...but as minicooper_s said, no need to remove DP.
Old Dec 3, 2017 | 09:19 PM
olpaul's Avatar
olpaul
on our 2008 s, I had to remove the downpipe and the inner shield to get to the oil filter housing bolts. Also had to drain coolant so it wouldn't run into the oil passages when the housing was pulled away from the block.. There is a good youtube video. I don't know about non turbo cars.
Old Dec 4, 2017 | 11:57 AM
Here is the DIY, I removed the DP and removed that back shield. I did the gasket and the oil turbo lines also.
Oil turbo lines
https://www.northamericanmotoring.co...-oil-line.html
Oil filter housing gasket
https://www.northamericanmotoring.co...placement.html
Old Dec 5, 2017 | 12:38 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Hello!
Yes, you will need to remove the down pipe and all of the heat shields in that area to fix that seat. I highly recommend installing this kit to fix all the leaks once and for all. There are also some directions on the page to cover it more in depth. http://www.detroittuned.com/dt-turbo...ine-super-kit/
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
dchernikoff
Mar 11, 2021 06:53 PM
bradyb
How to
31
Mar 3, 2019 03:45 PM
GearheadS
25
Dec 2, 2016 09:22 PM
Eid2000
Oct 17, 2016 11:27 AM
Mind.The.Gap
Oct 10, 2016 09:28 AM
