Foot Well Module!
Foot Well Module!
Took my 2010 to a shop with a very good reputation for some engine problems. Long story, but the engine problems were not repairable there.
My problem began when I showed up to retrieve the car at the shop.
The problem at first appeared to be a dead battery. We jumped started the car and drove it up on the trailer, but I noticed that the electric windows did not work.
The service manager said that they had determined that the Footwell module had died. He said that often happened due to moisture down there. Well, the car was dead anyway,so I just brought it home.
Upon testing, the electric windows, heater/ac, and high beams are affected.
Upon examination, the footwell module is dry and clean. No evidence of moisture at all. I did find this. (Picture)
It looks like a loose wire, but I think it is probably the place where the original dealership tapped power for the Oem rally lights they installed way back in 2010.
Following on advice I read on a different thread here, I disconnected the battery, removed the Football Module examined it (looks great), and re-installed it in hopes it would reset.
It did not.
What am I missing?
It did not.
What am I missing?
Arleen Franceschi (02-23-2021)
re: Foot Well Module!
Rhendy,
I had the battery on my 2010 MCS die on me & it damaged the Footwell Module . While chatting with an electrical engineer at work, he thinks it's probably a design flaw of not enough electrical protection in the components.
I replaced the battery to find the module dead, got it diagnosed, the dealer quoted $1100+ to fix it, I paid the $175 diagnostic fee & took it home. I contacted another local shop that specializes in Minis to do the repair, they quoted about $600-650.
George
George
chiming in...It is relatively easy/cheap fix. I have been restoring flooded minis for quite some time and this FRM isnt the only module i worked on. So this is first hand experience.
what you need to do is find a module with the same part number or an interchangeable one. use realoem.com to enter the last 7 numbers of the module. there it will show you other modules that can be interchanged with and from what cars.
After that buy inpa, winkfp, ncsexpert, ista/d, and ista/p (not really needed but nice to have) along with K+Dcan obd/usb cable.
also, where are you located?
cjv2 (12-26-2017)
Chiming in - 2011 MCS, 11/2010 manufacture date, pretty much same thing happened to me as the OP, back in August 2017. Had the battery disconnected for a good while while doing fuel system work, reconnected the battery and BAM, all the symptoms described (nasty little spark at the battery too -- yikes). Windows nonfunctional. Headlights stuck on and in low-beam. No other lighting controls operative of any kind. All the well-discussed symptoms of a dead FRM, and dealer diagnosed as a dead FRM. Diag confirmed at an independent shop that knows Minis *very* well. No water damage to speak of. The FRM just "had enough" of whatever it had enough of.
I agree with what gdfj12 got from talking with an electrical engineer -- this thing seems electrically flimsy to me. Car batteries get disconnected and reconnected all the time. If doing that fries electronics you haven't designed the electronics well. If I can ever figure out a good disconnect/reconnect solution to DIY onto this car that will absorb whatever caused that nasty spark I saw, I intend to implement it -- for now, that battery is staying connected no matter what I do unless my not-electrical-engineer-but-still-knows-some-stuff background says it's a dead necessity to disconnect. I don't need any more things frying out at several hundred $ at a time.
Independent shop tried replacing it with a used, which they've done before and know the drill on quite well -- but the used one that should have matched was pretty confused after reprogramming (window-up made windows go down and vice-versa). After a really strong effort we caved and just put in a new one.
Dealer wanted $887 before taxes and such. Got it done at the independent shop for $678. I hear there's a warranty extend on these things out there, looking into it.
GescomAe (07-30-2022)
Did you witness the shop installing the used one with the matching part number? Did you also get a chance to witness the reverse operation of the windows?
I find it odd that this would happen with a matching unit unless the unit is also faulty. I know in your case it said and done, but im puzzled.
as for the shock, you can use a capacitor to take the spark. just like in the audio system back in the day when we used to use a cap can (1F 12V or 25V).
cjv2 (12-26-2017)
I also seem to run into part number issues -- a whole lot -- due to having an early production MY2011 (November 2010 manufacture date). Apparently there was a whole lot of switching going on either just before or just after (or both). That could have been a factor as well, but no way to know at this point.
Thank you for that detail on the capacitor -- I was dancing around that idea but had no idea how to size it or how precisely to wire it up (positive side, negative side, blah blah). I figured I could sort the wiring fairly easily but I was at a loss as to cap sizing. I now officially owe you one... actually, two, with all that software detail!
I didnt mean to downgrade any shop but the more stories I hear, the less confident in shops I become. I personally rather waste the money and learn to benefit myself and members on NAM than waste it on a shop or worst yet, a dealer.
my now friend took his 2011 MCS to a known shop and the dealer and was told he needed an engine for a "spun bearing". he brought the car to me and guess what, that "spun bearing" was actually a chipping serpentine belt!!!
Minis are tricky, and it is hard to play with if you dont have tools. SW is the biggest investment and with it, you can almost win any fight
guspi76 (03-01-2019)
That shop, incidentally, is how I got to the Mini guy. It's turned out to be a crazy solid recommend.
But yeah, I hear you. And honestly, I'm looking forward to digging into the software. Kinda done with my days of saying to the FRM, "computer, please supply +12V to the circuit you shut off."
Hey MiniToBe -- back to the battery zap -- I was looking into the capacitor idea and ran into an interesting comment in a discussion of surge capacitors. The line that got my interest was this: "If the surge is of a low current relative to its voltage intensity, the capacitor will absorb it. If the surge has high current, the capacitor cannot absorb it." The conversation then discusses using an "arrestor" along with a surge capacitor.
I am not familiar with the technical underneath the way they use the term "arrestor." But it did occur to me that I have no idea what amount of current was going through that zap of my FRM, so it's at least a hypothetical concern. That got me Googling with some different terminology and I found my way into this very interesting class of intended-for-vehicles product.
Any thoughts on this stuff?
I think we aught to make a new thread for that stuff.
Surge arrestor is like a shock absorber. It is made to pretty much restrict excess current from passing. Once the current on the opposite side is equal to that of the other side then it lets the remaining current pass :-) make sense?
reinstall your original one and check the fuses at the fuse box.
FRM problems 2010 Mini Cooper R56
If this FRM is such a fragile unit in the system it is obviously a design flaw that the manufacturer should correct and make changes to the system so this cannot happen again. I missed the recall by 4 months and my battery just failed and being new to Mini didn't know you couldn't just plug a battery charger in and not do any damage. Who knew?
This problem appears to be far too common and would seem to be a candidate for a class action lawsuit. This failure has cost me a ton of lost time doing research and calling shops and dealers asking for help. The Dealers estimate to fix the problem if the problem is only the FRM was around $1500.
One BMW shop in town got a bit snipping on the phone when I asked if I could bring in the FRM to be reprogrammed. He said no matter what you read anywhere on the internet you need the entire car to reprogram the FRM. But that was going to cost $100 for diagnostics then if the FRM was the only problem, possibly $175 to reprogram.
I have sent the module to a shop who clams they can reprogram/repair the module. I have my fingers crossed.
Anyone have any information about any ongoing class action litigation?
