Halogen Headlight (not Bi-Xenon) Issue...
Old Oct 9, 2017 | 10:08 AM
RllyDrvrIX's Avatar
RllyDrvrIX
Hey group, thanks for reading and offering some help.
My passenger-side headlight, low-beam, needs to be adjusted upwards, a significant amount.
Forum threads correctly identify the adjustment screws addressing high-beam adjust. I've done that adjustment successfully and found the adjust screws very effective.
My issue is low-beam.
I've removed the bulb, made sure it's installed correctly, and it's still pointing far too low to be useful. I'e checked the mounting screws and they are all tight/secure in their correct locations.
Anyone else experience and solve this issue?
Old Oct 9, 2017 | 10:28 AM
Thinker2112's Avatar
Thinker2112
I didn't think that the low beams were adjustable...
Old Oct 11, 2017 | 03:35 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues area.
You have made sure that entire housing is mounted from beneath correctly?
Old Oct 11, 2017 | 08:11 AM
RllyDrvrIX's Avatar
RllyDrvrIX
I will double-check the install tonight. First pass with eyes and a 10mm didn't show anything out of the ordinary.
Old Oct 11, 2017 | 01:27 PM
Capt_bj's Avatar
Capt_bj
has it 'always been like this' or something new?
You have two (identical) bulbs in the housing? One is low other is high?
The first time I replaced one of the bulbs in my 02, my aim went out of whack. Eventually traced to the bulb being incorrectly seated. It looked good - altho it is hard to see in the open bonnet position. After a couple of tries I determined it was NOT in correctly and one it WAS correct everything was back to normal.
