Passenger window appears to not auto lower consistently
Old Sep 25, 2017 | 11:09 AM
NomadMac's Avatar
NomadMac
It appears that my passenger window appears to not auto lower consistently as there's a sharp crack noise when the passenger closes the door.
I thought at first my kid was slamming the door but I don't think it's him.
What controls the auto lower function just before and after closing the passenger door?
Old Sep 25, 2017 | 11:23 AM
nkfry's Avatar
nkfry
If the window isn't auto dipping chances are that the window motor is failing, but it could also be a door lock actuator fault.
If it's a door lock actuator fault I would assume you should also have a door ajar fault or the cabin lights wouldn't come on when the door is opened.
I would lean more towards a failing window motor though.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 25, 2017 | 11:25 AM
NomadMac's Avatar
NomadMac
Some more Googling and I found this in a BMW forum:
- Sit in the car, and put the key in position 1, so you have power to the windows.
- Push and hold down the window switch, and keep it held down for 5 seconds after the window is all the way down. This re-sets the memory, telling the motor, in effect, "Remember where we are now? Good."
- Roll window back up, and release switch.
Old Sep 25, 2017 | 03:36 PM
FlyByMike's Avatar
FlyByMike
The instructions from BMW forum could work -I think it's the same for the MINI. Your owner's manual will have (?) similar too. Did it work ?
What I don't like the "crack" part of your original post. It does sound like something is broken or out of place. So consider nkfry's post.
- Mike
Old Sep 25, 2017 | 07:47 PM
NomadMac's Avatar
NomadMac
The "cracking noise" is the passenger glass hitting the body frame, I believe, because it's not auto lowering. Since it's intermittent, I'm not sure that it's fixed.
Thanks for the input.
Old Sep 25, 2017 | 08:26 PM
FlyByMike's Avatar
FlyByMike
Crack:: Oh I see what you mean now. It is not moving out of the way as you open the door. About a half inch or so. There's an adjust procedure I saw for my F56 that you could try. Here's the link for it, try to get the pages for your model:
https://www.newtis.info/tisv2/a/en/
-Mike
Old Oct 3, 2017 | 02:37 PM
NomadMac's Avatar
NomadMac
I found a passenger door from a part out, without a crease in it and swapped it out hoping that it might fix my window auto-lowering issue.
Now the passenger door lock doesn't work with the key remote or the dash switch.
Suggestions?
