Replacing Harmonic Balancer Gen 1
Old Aug 20, 2017 | 04:29 PM
4aMiniManiac2's Avatar
4aMiniManiac2
2006 R52 Auto Trans. How do you stop the crankshaft from turning during the torque phase of replacing crank pulley.. Also the new pulley slips on with no pressure whatsoever
Old Aug 20, 2017 | 05:29 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Old Aug 21, 2017 | 01:53 PM
nkfry's Avatar
nkfry
There are ways of keeping the engine from turning over from a cam lock tool (which is a bit more involved to install a crank pulley), the supercharged cars can use a special tool that bolts to the damper, or in your case you can try sticking a prybar through the pulley and getting it to catch on the bumps behind the pulley on the timing cover and turn over until it locks in place and torque. (May require a buddy)
As for the pulley slipping on without effort; either the crank is damaged or the pulley ID is the wrong size and I wouldn't recommend installing it, they should be a press fit and torque.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 23, 2017 | 07:56 AM
4aMiniManiac2
Hi nkfry... I sent the pulley that slipped on back.. I just wasn't comfortable with the fit... Ordered a new one just waiting for it to arrive... Thanks for the reply....Paul
Old Aug 24, 2017 | 09:03 AM
monkeymike's Avatar
monkeymike
Read my recent post.... the last post is the write-up of how i did everything.
https://www.northamericanmotoring.co...y-removal.html
~mike
boiler up
How to
123
Aug 23, 2024 07:39 AM
JRoze
Jun 11, 2017 07:00 AM
sarom058
Oct 13, 2016 04:51 AM
S-Driver
Jan 8, 2016 05:31 PM
Wandersen
Aug 5, 2002 12:55 PM
