How do I remove the metal key part from the plastic case?
Old Mar 19, 2017 | 04:00 AM
NibblyPig's Avatar
NibblyPig
My mini key is old and broken so I bought a replacement case. I've popped out the electronics but the actual key bit I don't know how to remove.
Can anyone advise?
http://imgur.com/Llbrgry
Old Mar 19, 2017 | 07:26 AM
MannyJimenez's Avatar
MannyJimenez
That looks like it's press fitted. It doesn't look like there's a way to move it to your new fob with out the use of some form of silicone.
Hopefully someone else has a better answer.
Old Mar 19, 2017 | 07:40 AM
Whine not Walnuts's Avatar
Whine not Walnuts
It appears the key was riveted in place. Have you tried drilling the rivet out? I would probably use a plastic type epoxy along with a new rivet/screw to reattach.
Old Mar 19, 2017 | 09:29 AM
NibblyPig's Avatar
NibblyPig
No trick to it then? No worries I will take more extreme measures! Thanks
