This is not good... Oil in Coolant
When the engine is running, oil pressure is higher than the pressure in the cooling system, so oil tends to go to into the cooling system. If your coolant level is low and you have oil in the expansion tank, I'm afraid that might be a failed head gasket. The reason is your engine may be consuming the coolant through the combustion chamber.
Any overheating issues?
